Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Itunes Installation Problems
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello,
I recently purchased and Ipod and i have been trying in vain to install
Itunes and the ipod software onto my computer.The thing is i used to have
Itunes on my computer but then when i purchased my ipod and tried to install
the software but it didnt work so i unistalled itunes but i did so
improperly. I then downloaded Windows Install Cleanup, with this is was
successfully able to delete Itunes. However i still cannot install the ipod
software or itunes from the disc that came with my ipod or from the apple
site. An error message keeps popping up. "1628: Unable to Complete
Installation" . The installation stalls a while at "configuring windows
installer", then proceeds to installing but not even a second later the 1628
message appears. I have tried many troubleshooting tips but none have seemed
to work so far. I have windows XP professinal and service pack 2. I have had
my ipod 3 weeks and i havent been able to install anything. I would greatly
appreciate any help.
Thank You.
Djeinam
Sponsored Links
Djeinam wrote:
> Hello,
> install Itunes and the ipod software onto my computer.The thing is i
> used to have Itunes on my computer but then when i purchased my ipod
> and tried to install the software but it didnt work so i unistalled
> itunes but i did so improperly. I then downloaded Windows Install
> Cleanup, with this is was successfully able to delete Itunes. However
> i still cannot install the ipod software or itunes from the disc that
> came with my ipod or from the apple site. An error message keeps
> popping up. "1628: Unable to Complete Installation" . The installation
> stalls a while at "configuring windows installer", then proceeds to
> installing but not even a second later the 1628 message appears. I
> have tried many troubleshooting tips but none have seemed to work so
> far. I have windows XP professinal and service pack 2. I have had my
> greatly appreciate any help.
1. Are you connecting the iPod to a USB 2.0 port?
2. Did you install (or try to install) the software before connecting
the iPod?
3. What did Apple tech support say?
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
Hey Makle,
Thanks for answering. I know this might sound stupid but am i supposed to
plug my ipod in while i install the software??? I have been trying to install
the software before plugging in the ipod this whole time. I only plugged in
my ipod when i had itunes running before i deleted it to see if it would work
(i didnt). I have been writing to apple tech and they have sent me many
solutions and troubleshooting for 1628, they are really helpful, but
unfortunately none of it has worked yet. Thats when i decide to contact
microsoft. Any suggestions?
Thanks again.
"Malke" wrote:
> Djeinam wrote:
> > Hello,
> the iPod?
> Malke
> "Don't Panic!"
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle,
> to plug my ipod in while i install the software??? I have been trying
> to install the software before plugging in the ipod this whole time. I
> only plugged in my ipod when i had itunes running before i deleted it
> to see if it would work (i didnt). I have been writing to apple tech
> and they have sent me many solutions and troubleshooting for 1628,
> they are really helpful, but unfortunately none of it has worked yet.
> Thats when i decide to contact microsoft. Any suggestions?
> Thanks again.
With the iPod came a cd and an instruction manual with setup
information. You are supposed to put the cd in and start the install
and follow its wizard. No, you don't attach the iPod before you do
this. This installation software is *not* the same as iTunes.
Are you connecting your iPod with USB or Firewire? If USB, do you have
USB 2.0 ports?
Malke
"Don't Panic!"
Reply to Malke
Hey Makle,
Thanks for answering.I Have put the cd into the drive and tried to install
my software ( i may be technologically challanged but i figured that much).
The cd that came with my ipod containes the ipod software and version 4.9 of
itunes aswell. Both are included on the cd. My problem occurs during teh
installation. I have conversed with the support group at apple and we both
think that my problem is stemming either from the fact that i had itunes
earlier and uninstalled it improperly or from a problem within windows
installer (installation stalls a while when "configuring windows intaller" ).
The 1628: Failure to complete Installation error message always appears. I'm
connecting my ipod with a USB and i do have USB 2.0 ports. Hope that teh
information is clearer. Thanks again, i appreciate your help.
"Malke" wrote:
> Djeinam wrote:
> > Hey Makle,
> > Thanks again.
> USB 2.0 ports?
> Malke
> "Don't Panic!"
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle,
> install my software ( i may be technologically challanged but i
> figured that much). The cd that came with my ipod containes the ipod
> software and version 4.9 of itunes aswell. Both are included on the
> cd. My problem occurs during teh installation. I have conversed with
> the support group at apple and we both think that my problem is
> stemming either from the fact that i had itunes earlier and
> uninstalled it improperly or from a problem within windows installer
> (installation stalls a while when "configuring windows intaller" ). The
> I'm connecting my ipod with a USB and i do have USB 2.0 ports. Hope
> that teh information is clearer. Thanks again, i appreciate your help.
That *is* clearer, thanks. It would have been good to describe what
"uninstalled it improperly" means exactly, though. Did you just delete
the program folder instead of using Add/Remove Programs? Things to try:
1. Do a System Restore to before you uninstalled iTunes and tried to
install the iPod.
2. If that isn't possible, install iTunes again by itself (not from the
iPod cd). Don't bother to uninstall it before running the iPod
software.
3. If you run into a problem doing any installation, try the Windows
Installer Cleanup Utility:
http://support.microsoft.com/defau [...] -us;290301
Malke
"Don't Panic!"
Reply to Malke
Hey Makle,
What i mean by "uninstalled improperly" is that like you guessed i just
deleted the program file without going to remove/add programs. I then
consulted apple tech and they told me to use the Windows Intall cleanip
utility. I used it and got rid of itunes properly. It doesnt appear in remoe
or add programs anymore. its gone (except when i insert a blank cd into my
computer teh option to burn a cd using itunes is still available, but when i
clicke don it it just brings me to a list of other programs i might use,
other than that its gone) So i used the windows install cleanup, but i still
cant dowlad itunes or install the ipod software. (not from the interenet or
the disc.) I can save it on my computer from the internet but as soon as i
try to run the installation, i get the 1628: Failure to complete intsallation
error message. I have tried cleaning my temp and teh other troubleshooting
point soffere dby apple, but still no luck! I was suggested to uninstall
service pack to and then reintsall it to install itunes. What do you think of
this solution? What are the affects it will have on my files (music
documents) ? Thanks again!
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle,
> just deleted the program file without going to remove/add programs. I
> then consulted apple tech and they told me to use the Windows Intall
> cleanip utility. I used it and got rid of itunes properly. It doesnt
> appear in remoe or add programs anymore. its gone (except when i
> insert a blank cd into my computer teh option to burn a cd using
> itunes is still available, but when i clicke don it it just brings me
> to a list of other programs i might use, other than that its gone) So
> i used the windows install cleanup, but i still cant dowlad itunes or
> install the ipod software. (not from the interenet or the disc.) I can
> save it on my computer from the internet but as soon as i try to run
> troubleshooting point soffere dby apple, but still no luck! I was
> suggested to uninstall service pack to and then reintsall it to
> install itunes. What do you think of this solution? What are the
> affects it will have on my files (music documents) ? Thanks again!
I certainly would not remove Service Pack 2 for this issue. Try a System
Restore to before you deleted the original iTunes or reinstall iTunes
like I suggested in my previous post.
Malke
"Don't Panic!"
Reply to Malke
Hey Makle,
My problem is that i *cant* reinstall itunes. Not from the disc, from the
internet nothing. I keep getting the error message. (1628) I have completly
deleted itunes (emptied my recycling bin and all) but i havent tried the
system restore thing because i dont know how to do that could you please
enlighten me? "Try a System Restore to before you deleted the original
iTunes "
Thanks so much for all the help so far!!!!
"Malke" wrote:
> Djeinam wrote:
> > Hey Makle,
> Malke
> "Don't Panic!"
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle,
> the internet nothing. I keep getting the error message. (1628) I have
> completly
> the system restore thing because i dont know how to do that could you
> please
> original iTunes "
Start>All Programs>Accessories>System Tools>System Restore
"Restore my computer to an earlier date". Follow the wizard. Pick a date
before you deleted the iTunes folder the first time.
Malke
"Don't Panic!"
Reply to Malke
Hey Makle
Thanks for answering. Unfortunately no luck with teh System restore method.
I cant do this because there are no restore points available! Any other
suggestions? Thanks again
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle
> method. I cant do this because there are no restore points available!
> Any other suggestions? Thanks again
You are now at the point where the computer needs on-site service.
Someone needs to be actually able to see your machine and address the
problems hands-on. This cannot be done in a newsgroup.
Take your machine to a professional computer repair shop (not your local
equivalent of BigStoreUSA). They will be able to remove all the
registry entries left from your improper uninstall and see if there are
other problems that are affecting the machine. There is no way you
should go messing in the registry yourself. I don't say that to hurt
your feelings, but am going based on the skill level shown from your
posts. One false move in the registry and you can hose your Windows
installation. Take your iPod with you so they can install it for you.
Good luck,
Malke
"Don't Panic!"
Reply to Malke
Hey Makle,
Thansk for answering again. Don'y worry i am well aware of my skill level
when it comes to computers (no offense taken), but it is impossible for me to
do so, because im not in the USA anymore. I bought my ipod and then left the
country. Im in West africa now. I can try contacting a professional here, but
you told me not to go to the equivelant of a BigStore USA. Is my case
hopeless? Thanks for all your help.
Reply to Anonymous
Exactly Right - I cannot tell you how many times I've been called
for a problem/issue that if the user had stopped "Trying" all sorts
of things it would have been much easier/cheaper to fix up. There
are two things in everyone's house that are easy to screw up by
not knowing when to stop working on them and call a professional
- Plumbing & PCs.
"Malke" <invalid@not-real.com> wrote in message
news:u%23f4YtKqFHA.272@TK2MSFTNGP15.phx.gbl...
> Djeinam wrote:
>> Hey Makle
> Good luck,
> Malke
> "Don't Panic!"
Reply to Anonymous
- 0 +
Djeinam wrote:
> Hey Makle,
> level when it comes to computers (no offense taken), but it is
> impossible for me to do so, because im not in the USA anymore. I
> bought my ipod and then left the country. Im in West africa now. I can
Obviously you will need to go to whatever is available where you are.
Malke
"Don't Panic!"
Reply to Malke
Hey,
Thanks for all your help Makle. I have corrupt files in my computer. Im
getting it re-formatted.
Reply to Anonymous
There are 1054 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
