Remote Desktop Problem
Forum Windows XP : Windows XP General Discussion - Remote Desktop Problem
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello,
I'm currently managing a group of approximately 175 systems in ten
locations, all running XP Pro, SP2, all updates, etc.
The network is VPN'd through routers for a full time connection.
Each location can be accessed from all other locations using Remote
Desktop Connection with the exception of one.
However, the VPN is fully functional, as you can ping or use other
programs such a Real VNC without any problems.
Okay, here's where it gets weird:
From any location you can access the computers with RDC in the suspect
location from some machines, but not others. When you try to access a
remote system, RDC hangs and the logon screen never appears and has to
be closed through task manager. From the next computer in the same
location, it logs on to the exact same remote system without any
problems.
Real VNC works without any problems, as does PCAnywhere. Only RDC has
this issue, and ONLY in one location, and not from all computers in
the same location on the same network trying to access the remote VPN
systems.
Hope this made some sense.
Any ideas?
Thanks,
Mitch
Sponsored Links
Hi. I think i can help you whats going on..... I had this same problem too.
For some occasion, 50 50 chance tho. Your computer has Internet Connection
Proxy Settings. You cannot modify these settings, by anything. No program
can modify this. This cannot be modified, by any administrator. Even if
they are an Expert.
You connection proxy settings are either blocking your connections. Not all
programs support Proxy Configurations. Hopes this helps, what is going on.
"Mitch" wrote:
> Hello,
> problems.
> systems.
> Any ideas?
> Thanks,
> Mitch
Reply to Anonymous
On Tue, 23 Aug 2005 00:44:04 -0700, "jasonkruser"
>they are an Expert.
Hi Jason,
Issue solved. Turns out the location giving us this odd behavior (the
only locale with DSL for the record) must have some noise on the line.
Packet loss did not appear to be a problem as we could not get any
readings indicating such. However, we disabled router settings at all
locations which were set to drop fragmented IP packets, and the
weirdness ended. I love DSL, really I do.
Thanks for your suggestion nonetheless.
Mitch
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remote Desktop Problem
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
