G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hello,
You all are so knowledgeable. I wonder if anyone can tell me if you have
any hints on how to get my memory in. I have a Dell Dimension 2400 with
128MB. Need to install more memory and after research bought PNY 512MB
PC2700 DDR333 at Best Buy and was assured it would be fine.
However when I got in to snap it in (everything aligned that I can tell) I
could not get it to go in the 2nd memory slot.
Any hints would be appreciated....or did I plain just buy the wrong stuff.
I tried calling Dell support but listened to music for 3 hours. UGH!
I was so proud that I got the memory got into the machine following the
directions and then no go!!
Also how can I join this newgroup officially?
Thanks, Maureen
Hello,
Thanks, Maureen
