Yes No
Ads
Tom's Hardware > Forum > Home Theatre > DVD Players, Set-Top-Boxes > Panasonic SA-HT400/HT390 PROBLEMS
Forum Home Theatre : DVD Players, Set-Top-Boxes Panasonic SA-HT400/HT390 PROBLEMS
Problem just started. When playing DVD's I can hear only back ground music. No voices. ? ?
Reply to Bill Bell
Sounds like your center channel went out. Check the wires connecting to the center channel speaker. Try swapping them out with a known working speaker wire.
-Wolf sends
------------------------------ All Purpose System Specs: GA-H55M-S2V Intel CoreI5 760 8 Gig RAM NVidia Geforce 8800GTS-640 Windows 7
HTPC System Specs: ASRock 760GM-GS3 AMD Athlon II X2-240 G.Skill 4 GB (2x2GB) Radeon HD4670 Ceton InfiniTV4 TV Tuner
Reply to Wolfshadw
Thanks for your reply. Maybe I should be more specific and tell you more. I did try the test mode before and the center speaker does work. I have some DVD'S of my own that play fine. God figure ?
This problem seems to have started in maybe the last 4 or 5 DVD'S that I rented and one that I just purchased. I took the one I purchased to a friends and it ran fine.
Any chance the DVD player may be causing this problem ? It's a Panasonic DVD-F85. The first page of the DVD manual tells about how it can run RAM , DVD-A, DVDV etc.
Reply to Bill Bell
Any more thoughts to my problem ?
Reply to Bill Bell
Simplest solution would be for your friend to bring his/her DVD player over and hook up to your sound system. If the center channel plays fine with the same DVD, then it's an issue with your DVD player. If the issue persists, then it's an issue with your sound system.
-Wolf sends
Reply to Wolfshadw
-Wolf sends
That's too easy. Why didn't I think of that !
I will do that and let you know what happens.
Thanks
Reply to Bill Bell
-Wolf sends
Thanks for all the help Wolf. It was the sound system. It looks like the Digital/analog input select button/indicator may be the culprit. I'm going to take the unit somewhere and have a technician have a look. If that costs too much ( I'm retired ) I will break down and buy a new system.
Thanks again
Bill
Reply to Bill Bell
Good luck!
-Wolf sends
Reply to Wolfshadw
There are 1983 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 24 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
