Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem after installing SP2
Archived from groups: microsoft.public.windowsxp.general (More info?)
I recently have been having a problem that is really driving me crazy. I
have recently updated XP pro to SP2. I am having a problem now
right-clicking files anywhere on my system. Windows will hang and give me an
error about "Dr. Watson postmortem has caused an error and needs to close".
After waiting a minute or two explorer.exe will close and open again and I
receive an event id 1002 saying "The shell stopped unexpectedly and
Explorer.exe was restarted."
What makes this even weirder is that I can right click on shortcuts and
other desktop icons with no problem, its just when I right click files no
matter where they are either on the desktop or somewhere on the harddrive.
I have uninstalled SP2 and tried to see if the problem went away and yes it
did. I then reinstalled SP2 again and the problem is back!
Any ideas? Thank you
Sponsored Links
1. Uninstall SP2 via Add/Remove Programs and reboot.
2. Run a thorough check for hijackware, including posting your HijackThis
log to an appropriate forum.
Check for Hijackware
http://aumha.org/a/parasite.htm
http://aumha.org/a/quickfix.htm
http://mvps.org/winhelp2002/unwanted.htm
http://inetexplorer.mvps.org/Darnit.htm
http://www.mvps.org/sramesh2k/Malware_Defence.htm
http://defendingyourmachine.blogspot.com/
When all else fails, HijackThis (http://aumha.net/downloads/hijackthis.zip)
is the preferred tool to use. It will help you to both identify and remove
any hijackware/spyware.
**Post your HijackThis log to http://forums.spywareinfo.com/,
http://castlecops.com/forum67.html, http://aumha.net/viewforum.php?f=30 or
other appropriate forum for expert analysis, not here.**
3. Do not install SP2 until an expert gives your HijackThis log a clean bill
of health.
Also see:
What to Know Before Downloading/Installing SP2
http://www.microsoft.com/windowsxp [...] oknow.mspx
Installing SP2 Step-by-Step
http://support.microsoft.com/default.aspx?scid=fh;[ln];xpsp2insthowto
Troubleshooting Your Installation
http://support.microsoft.com/default.aspx?scid=fh;[ln];xpsp2insttshoot
WinXP SP2 FAQ: What to do after installing SP2
http://support.microsoft.com/defau [...] 2installed
Service Pack (any) Installation Checklist (MVP Jupiter Jones)
http://www3.telus.net/dandemar/spackins.htm
WinXP SP2-specific Page (MVP Jupiter Jones)
http://www3.telus.net/dandemar/xpsp2.htm
The hard disk space requirements for Windows XP Service Pack 2
http://support.microsoft.com/default.aspx?kbid=837783
~Robear Dyer (PA Bear)
MS MVP-Windows (IE/OE, Shell/User, Security), AH-VSOP
> me an error about "Dr. Watson postmortem has caused an error and needs to
> close". After waiting a minute or two explorer.exe will close and open
> again and I receive an event id 1002 saying "The shell stopped
> unexpectedly and Explorer.exe was restarted."
> it did. I then reinstalled SP2 again and the problem is back!
Reply to Anonymous
- 0 +
In addition to PA Bear's advice this problem can be caused for certain
context menu handlers. See these links:
http://www.winxptutor.com/sp2/divxcrash.htm
"Right-click is slow or weird behavior caused by context menu handlers"
http://windowsxp.mvps.org/slowrightclick.htm
Rock
MS MVP Windows - Shell/User
Reply to Rock
There are 746 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
