Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Delete Drop Down Menu History From IE problem
Forum Windows XP : Windows XP General Discussion - Delete Drop Down Menu History From IE problem
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have been trying to delete my drop down history from Internet Explorer, but
some of the pages still appear after I have deleted them. I have gone into
the Control Panal and Internet Options, and clicked Clear History. It has
cleared about 95% of the pages, but still there are a few that seem to remain
in my drop down window. The same ones never delete. None of the pages that
remain have been saved as favorites and there is no trace of them in my
temporary internet files. For example, if I start typing out a web address
that starts with "www.y", the drop down window automatically opens and gives
me the the choice of "www.yahoo.com", even though I have deleted the history
and it's not saved as a favorite. Why does that keep happening, and how do I
delete those remaining ones? Thanks for the help.
Sponsored Links
Hi,
These URLs you're seeing are in the index.dat file in the History folder.
CCleaner from http://www.ccleaner.com/ should be able to clear the History
and the index.dat file. Just check the appropriate boxes and run it.
Or, Free History Eraser from
http://smartprotector.com/eraser/f [...] eraser.htm will delete the
History folder (and the index.dat file) and a new one will be created when
you restart.
Or the History folder can be deleted manually:
http://mvps.org/winhelp2002/delcache.htm
Hope this helps,
Don
[MS MVP- IE/OE]
"DP" <DP[at]discussions.microsoft.com> wrote in message
news:77D89206-B8A4-40B7-A87E-53718918373B@microsoft.com...
but
into
remain
that
address
gives
history
do I
Reply to Anonymous
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
