Problem with Fan on DELL latitude - plz help!
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have an annoying problem with my dual Fan C810 laptop.
After some hours usage (usually) the fans when turned on
(automatically) make a grating noise - very loud and can be heard in
the next room.
I suspect it has something to do with heat expanding the plastic? As
after cooling the fans seem to revert to normal behavior.
The behavior affects both fans - sometimes simultaneously sometimes in
isolation (I used a fan control program to test this)
I have managed to make the problem acceptable by running the CPU
permanently at 733MHZ (speedstepped from 1.13GHZ) - no great problem
for me as I only surf the web and use Office programs - but the
problem doesn't go away as the fans invariably need to be used and
switch on automatically and voila.... after a while the grating noise
reappears.
The Fan control program I use "Fan Control 2.2.0" by Christian Diefer
allows me to turn off the fans permanently. Now.. at 1.13GHZ I guess
this would make for a fried motherboard - but speedstepped permanently
to 733MHZ (via the authors Speedswitch XP) could I get away with this?
The temperature at the lower speed rarely reaches 60C and averages
around 52-55C... cooling required?
Thanks for any help
Chris
I can be e-mailed at: athena (at) rol (dot) ru
3 answers Last reply
More about problem dell latitude help
  1. Archived from groups: alt.sys.pc-clone.dell (More info?)
    replace the fan and run the system as it was designed. there are several of
    those fans listed on ebay starting at $10 (perhaps the same price as dell?)
    and the service manual is available for free here
    http://docs.us.dell.com/docs/systems/latc810/sm_en/index.htm
    "rfc" <rfc2000@usa.net> wrote in message
    news:rlhc90lq8su6kg6njj20i36dambie6o2g0@4ax.com...
    > the next room.
    > reappears.
    > Thanks for any help
    > Chris
  2. Archived from groups: alt.sys.pc-clone.dell (More info?)
    On Mon, 03 May 2004 14:05:23 GMT, "Christopher Muto"
    Thanks for the advice - however having an earlier C800 the same
    problem occurred leading me to believe it is integral in the design
    and a new fan would perform similarly under heat stress
    What I need to know is as before, does the CPU need cooling below 60C?
    thanks
    >> the next room.
    >> reappears.
    >> Thanks for any help
    >> Chris
  3. Archived from groups: alt.sys.pc-clone.dell (More info?)
    i like to solve the cause of a problem and not a symptom... but this should
    help you decide whatever it is that you want to do...
    http://www.intel.com/support/processors/mobile/pentiumiii/sb/cs-007510.htm
    news:j8lc905a6d41k0ahed13i8vckt18ro56gh@4ax.com...
    of
    dell?)
    > thanks
    > >> the next room.
    > >> reappears.
    > >> Thanks for any help
    > >> Chris
Dell Computers Product
