I was in the middle of playing Warcraft 3, when my computer just conked out.
I attempted to turn it back on, nothing. My NIC leds on the motherboard remained on. I whipped the HSF off my proc. No visible damage or frying.
But my PS has an odd smell coming from it, I could almost say burning but im not sure whether it normally makes that smell or not as I havent smelled my PSU during normal operation before. I don't want to open my PSU yet as I'm not sure whether I still have a warranty on it or not.
Unfortunately its a generic 300W psu, I'm OC'ing, I've recently added a cold cathode to my system, I have my cpu fan, 2 case fans, video card fan, one HDD, and one optical drive.
I believe I might have overloaded it, is there anyway to test it to be sure. Fast response would be most appreciated as I have to go off to work soon.
If you have a multimeter, you can usi it! Turn the PSU on and check if you have 12 Volts and 5 Volts at your power connectors.
A good indication is the PSU fan... If this fan don't work... Your PSU is probably damaged.
And don't be afraid to open the PSU cover. Usually when a PSU is dead, a visual inspectionis sufficient to see what components fried or exploded. Check at the base of components to see for "black burned" spots. And check that all condensators (little "canisters" ) are intact.
There's a sticker covering the opening though, it says warranty void if removed, won't my warranty be voided if I remove this cover? As well, I removed the PSU from my system, could I also test for connectivity using an ohm-meter or ohm function of a multimeter to see if there are any dead connections?
First... If you are still in your WARRANTY period. Get your PSU to your computer dealer, he will test it. If it's dead. They will replace it for free! If you replace your PSU, don't forget to get a 350 Watts PSU of quality. YOu may have to pay the difference, but this will ensure PC stability and PSU durability.
If your warranty period have expired. Don't be afraid to open your PSU.
For the OhmMeter... Humm... They are good when you know what resistance you expect between the mesurements points. A long time ago (6 years) I graduated in electronics. I used a lot my OhmMeter fonction on my MultiMeter, but I always had circuits diagram and I knew what to expect from my mesurements... So, without circuits diagrams, it's harder to know if you see on the Meter is good or not. usually, when you have resistance that tends to inifinity (high resistance), you have an open circuit, so no electricy is goind from A to B. And on the other hand, when resistance tend to 0, you have a short-circuit or a direct connection. So ALL the current (electricity) will pass from point A to B.
I will have to hook up the PSU to the motherboard in order to test it correct? It will most likely wreck it if it isn't already if I don't have something drawing from it? I'm just wondering if this can do damage or not to other components of my PC
PSU can kill other components. But, usually when a PSU dies an "open circuit" is "created". So no current can reach the motherboard or components. But what might happen is some "spikes" or "short-circuit" condition he se situation can kill weak component or even good component if these spikes are too big.
I must admit that I have a couple of PSU dying in friend's PC and they never lost other components. Maybe, they were lucky!
Here...Scrap the old one...buy a new one....<A HREF="http://www.newegg.com/app/viewproduct.asp?description=17-154-013&DEPA=1" target="_new">http://www.newegg.com/app/viewproduct.asp?description=17-154-013&DEPA=1</A>
Decent power
Cheap
two day shipping
Good vendor
Save headaches, just buy it...
Fried my 350w PSU last weekend and all my other components were still intact, same thing happened to a friend of mine around half a year ago. so lucky lucky
Only problem, is is that i'm gonna have to determine if it IS the power supply that is fried. Hopefully it is, although on first glance inside my PSU (warranty is definately gone now ) I don't see anything, but i'm gonna have a go with the multimeter and see what I can find.
<A HREF="http://www.motherboardrepair.com/index.php?sec=images" target="_new">http://www.motherboardrepair.com/index.php?sec=images</A>
Inspect ur Mobo for blown capacitors and burned toroid coils. Can't hurt to look
Well I took a peek at the underside of the PCB of the power supply and there seems to be a part where there's some brownish stuff on the board and solder connections, i'm not sure whether it's some form of oxidation (from burning) or just flux, although it's odd that it's only in the one part of the PCB, and not anywhere else.
Any suggestions on what I could be looking for... also, if I wanted to test the voltage on the PSU i would have to plug it in, but I was wondering if this could damage it (if it's not damaged already) by not putting any loads on it.
My toroid coils look fine, but from the pictures it's a bit hard to tell how to know if your caps are bad? Is there a particular visible sign which shows you?
OK, I looked up some more on caps and I don't appear to have that problem. I was wondering what's the best way to test the PSU, one way I read was to connecct the green PS_ON line to a ground line and then turn the PS switch at the back of the unit on and see if it comes on, is this a good approach?
Okay, I know this isn't helpful, but I couldn't resist...
<b><font color=red>*** WARNING! BAD PUN TO FOLLOW! ***</b></font color=red>
It may sound strange, but the best way to deal with Major Problem is to promote him. He gets easier to handle as he climbs the ranks.
For example, promote him to Colonel (Kernel) Problem and your PC will start booting up again. It might be unstable everyone once in a while or act a little flakey, but that's a big improvement from not working at all.
Promote him a step after than and he's only General Problem then. That makes him very easy to handle. He could be as simple as an IRQ conflict or a loose cable then.
<b><font color=red>*** BAD PUN OVER. ***</b></font color=red>
<font color=purple><pre><A HREF="http://www.winamp.com" target="_new">Winamp<b><font color=blue>3</font color=blue></b></A> and freeform skins, the best thing since sliced llama loaf. (Now with more beef.)</pre><p></font color=purple>
