Logitech z506 won't play surround sound
I just bought the Logitech Z506 5.1 speaker system, and I can't get it to play through all 5 speakers. I use my laptop, which has 2 audio jacks (there's a microphone jack too, I didn't try to plug it in there), so I can only plug in 2 of the 3 cables.
The speakers are supposed (I think) to have some kind of forced surround sound output so that stereo input is played in surround, but if I only plug in the front speakers, all that plays are the left and right speakers and the sub. If I plug in 2 of the cables, those two things will play, but not the third.
I tried using a splitter, with one cable plugged in directly and the other two sharing the splitter, but that seems to overpower the speakers that aren't using the splitter.
After about a day of this, I ordered the GWC Technology AA1500 USB Audio Adapter (5.1 Channel), which is supposed to convert sound to 5.1, and it does have the 3 jacks for a 5.1 system, but when I plugged it in, installed the drivers, and tried to use it, it only played sound through the Front port. I tried going to (in Windows 7) Control Panel -> Sound -> Speakers -> Configure and setting playback to 5.1 Surround instead of Stereo, but the problem remains. The output is still only through the front jack.
Before these speakers I used a cheaper 5.1 system, the CA 5402, and even with only 2 cables plugged in, those speakers all played. I really don't understand why the Z506 won't just port sound from the front left and right to the rear like my old ones did. I tried plugging the satellites from the Z506 into the sub from the CA 5402 with only the front and center/sub cables plugged in and I got equal sound from every speaker, just like I wanted. Any ideas on why I can't get this from the Z506?
Reply to throughfire
8 answers Last reply
More about logitech z506 play surround sound
  1. unplug the black and orange jacks from the subwoofer
    Reply to Anonymous
  2. make sure your song or movie have 6 channel audio (right click on that properties and then click on details TAB on audio section check channel mostly songs have 2(stereo) best of luck
    and sry for english
    Reply to rajat501
  3. i bought this product 2 years ago from local market, and all i have to say is that quite an awesome product it is and i am its proud owner, but my review is dedicated to those who are having problems with rear speakers/ are not getting surround sound experience.
    1. make sure that you have 5.1 setup enabled in your audio driver settings.
    2. make sure that the file you are playing consists of 6 channel audio, to check it right click on file and then properties.
    3. make sure that the media player which is being used to play the file has 5.1 speakers option enabled. windows media player is by default enabled but vlc media player requires to select the speaker type for 5.1 speakers.
    4. to get better output, enhance rear speaker sound level to +10dB in audio driver settings.
    Reply to rajat501
  4. This is something I had a problem with and have found the solution.
    The old Via HD Audio Deck installed on my Windows 7 which worked perfectly didn't support Windows 10.
    If you have a mother board installation disc it'll probably have the Windows 7 to 8 driver but not the one for Windows 10.
    Just go online and download the current version and it may very well do the trick for you.
    Please post up the results so others may find the topic.
    My angst is that the manufacturer doesn't seem to give a damn and relies on their customers to find answers to their problems. In fact I even have a sound card on the way to me right now that I thought I may have to use but I found the answer in the meantime.
    Never mind. Problem solved and all's working well. Terrific sound in my lounge with animals coming at me from all angles on Avatar. Oh, and did you try the stampeding buffalo in Dances with Wolves?
    Reply to Lynnzer
    Reply to Ampon_
  6. try using an 1/8 inch stereo jack to red and white rca jacks that might work
    Reply to CWL900
    Hey thanks for your answer! I just got these speakers, and I've never had any like these before. I plugged everything into my desktop. Everything was working except for the rear speakers. Once I unplugged and took out the sound-card cables (black and orange jacks), the rear speakers came on.
    Reply to Julie021
    A definate thank you. Mine was working,then quit after an update....removing Black & orange cables did the trick.
    Reply to vindicator6
Ask a new question Answer
Speakers Cable Logitech Audio
