Archived from groups: rec.games.pinball (
More info?)
Cool- thanks for the info- saves me a trip to the file cabinet to check!
Ray J.
Action Pinball & Amusement, LLC
Salt Lake City, Utah USA
Web: www.actionpinball.com
We're serious about pinball. Anything else is just for fun!
<cfh@provide.net> wrote in message
news:1121477542.615636.312440@z14g2000cwz.googlegroups.com...
> Ray i wish you were right!
> But the guy that posted is right. Bally lists both 115 and 120
> volt selections.
> I just converted a Fathom for a guy, and this puzzled me too.
> Do i convert it to 120 or 115 volts? around here voltages
> seem to be 120 volts, so i converted to 120. My thinking was
> this... if i convert it to 115 volts, the +5 and +170 volt
> will be fine as they are regulated. But what about the 6 volt
> GI and CPU lights? they will burn a little brigher and hotter
> if the game is set to 115 instead of 120. So i went with the
> 120 volt conversion, figuring it would save light bulbs and
> maybe connectors too. But i don't know if i choose right!
> Ray Johnson - Action Pinball wrote:
> > No change needed- 115-125 vac input is fine for the "115 vac"
transformer
> > setting. Line voltage normally varies depending on where you live- can
be
> > anything from 110-125vac and still be safe.
> > I believe they only have three settings/configurations available on
these
> > units- "115 vac", low line (105vac) and European "230 vac".
> > Ray J.
> > "Rick" <rblethen@yahoo.com> wrote in message
> > news:1121463284.803029.172740@g44g2000cwa.googlegroups.com...
> > > I bought a used transformer and rectifier board for my Bally Paragon
> > > "project" machine.
> > > The transformer is currently set for input = 115VAC. My house current
> > > is a rather consistent 120VAC.
> > > I would rather not change the tranformer jumpers (If it a'int broke
> > > don't fix it).
> > > My question is: Do I really need to change the transformer jumpers
from
> > > a 115volt setting to a 120volt.
> > > This newbie thanks you in advance for the guidance.
> > > Rick
