G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi,
I have a genesis pinball that I have gone through and done mostly all
the fixes recomended. The Problem is everything ( pop bumpers, slings,
gates, swts) all work. But the game has no sound or music, UNLESS you
take the edge connector and pull it off alittle .( you get a new sound
or music every time you sort of pulse it like that during game play.)
Any hints on what to check? The sounds are there , just not triggered
from the right devices on the playfield.
Thanks
Jay
Hi,
Thanks
Jay
