Sign-in / Sign-up
Right-click problem
  • System File
  • Microsoft
  • Windows XP
Last response: in Windows XP
August 26, 2005 2:28:53 AM
Archived from groups: microsoft.public.windowsxp.general (More info?)
Whenever I right click a file, my PC hangs.
I think some system file has been corrupted.
Is there any fox for this apart from re-installing XP? I'm running XP Pro
SP2 with all the updates.
Cheers.
Bobby
More about : click problem
Anonymous
August 26, 2005 2:28:54 AM
Hi,
Use ShellExView from http://www.nirsoft.net/utils/shexview.html to disable
context menu items until you find the troublesome one.
Excellent information at http://windowsxp.mvps.org/slowrightclick.htm
Don
[MS MVP- IE/OE]
"Bobby" <bobby[at]aventuremail.com> wrote in message
news:3n6rgmF5m8qU1@individual.net...
> Cheers.
> Bobby
August 27, 2005 3:05:17 PM
Thanks Don.
I tried to use this program by disabling various non-MS programs but my PC
still hangs when I right click. The annoying thing is that it's fine other
than this - so I'm very reluctant to re-install XP.
Any ideas?
Bobby
"Don Varnau" <don_04[at]varnau[dot]org> wrote in message
news:ubSFjzbqFHA.3160@TK2MSFTNGP14.phx.gbl...
> Hi,
> Don
> [MS MVP- IE/OE]
>> Cheers.
>> Bobby
August 27, 2005 3:05:18 PM
Bobby wrote:
> Thanks Don.
> my PC still hangs when I right click. The annoying thing is that it's
> fine other than this - so I'm very reluctant to re-install XP.
> Any ideas?
> Bobby
>> Hi,
>> disable context menu items until you find the troublesome one.
>> Don
>> [MS MVP- IE/OE]
>>> XP Pro SP2 with all the updates.
Here are some other links that may help:
Right click causes an error and crashes Explorer.exe after installing
Windows XP SP2 - http://www.winxptutor.com/sp2/divxcrash.htm
Manage the context-menu entries for folders, drives and Namespace
objects - http://windowsxp.mvps.org/context_folders.htm
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
August 27, 2005 11:19:42 PM
Hey Don. I did as you suggested properly instead of randomly (doh!)
disabling handlers.
My problem disappeared when I disabled all non-MS handlers - so I just
enabled one at a time and discovered the culprit.
Cheers. I'll buy you a dram when you next visit Glasgow.
Bobby
> Hi,
> Don
> [MS MVP- IE/OE]
>> Cheers.
>> Bobby
