problem installing xp
Archived from groups: microsoft.public.windowsxp.general (More info?)
This is a continuation of the last post I had a couple days ago. I have a
new hdd. I am trying to install xp on it and having nothing but problems.
It runs through the set up and then gets so far and says that there is a
problem with the set up and installation cannot continue. It says that it
could be a damaged disk. The disk is not damaged, as it is brand new. I
called the manuf. of the hdd and they said it is a windows problem. I am
getting a stop error screen with the following information:
Problem caused by the following file: partmgr.sys
DRIVER_UNLOADED_WITHOUT_CANCELLING_PENDING_OPERATIONS
Disable BIOS memory options such as caching or shadowing.
Tech Information:
***STOP: 0x000000CE (0xF87CD667, 0x00000000, 0xF87CD667, 0x00000000)
partmgr.sys
Does anyone have any information or suggestions for me? This is really
starting to piss me off.
Stacy
11 answers Last reply
More about problem installing
  1. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > have a
    > problems. It runs through the set up and then gets so far and says
    > that there is a
    > that it
    > I
    > am getting a stop error screen with the following information:
    > Tech Information:
    > partmgr.sys
    I don't know what you did or posted about a few days ago, but did you
    test your RAM? Bad, flaky, marginal RAM is one of the prime suspects
    when an operating system won't install. Test the RAM - I like
    Memtest86+ from www.memtest.org. Obviously, you have to get the program
    from a working machine. You will either download the precompiled
    Windows binary to make a bootable floppy or the .iso to make a bootable
    cd. If you want to use the latter, you'll need to have third-party
    burning software on the machine where you download the file - XP's
    built-in burning capability won't do the job. In either case, boot with
    the media you made. The test will run immediately. Let the test run for
    an extended period of time like an hour or two - unless errors are seen
    immediately. If you get any errors, replace the RAM.
    Malke
    Elephant Boy Computers
    www.elephantboycomputers.com
    "Don't Panic!"
    MS-MVP Windows - Shell/User
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    I know there is nothing wrong with the RAM. Everything in the computer is
    new. The only thing that isn't new is 1 of the cd drives. The motherboard
    went out and we just replaced that along with new RAM to fit the motherboard.
    "Malke" wrote:
    > > have a
    > > that there is a
    > > that it
    > > I
    > > Tech Information:
    > > partmgr.sys
    > Malke
    > "Don't Panic!"
  3. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Stacy
    Download the diagnostic program from the HDD manufacturer website, and run
    it.. also run the 'write zeros' function, which will completely remove all
    partitions and everything else from the drive.. then use a Win 98 boot
    diskette to partition and format the drive.. if it glitches at any point,
    the drive has a problem.. if it doesn't, try to run the XP setup procedure
    again..
    Mike Hall
    MVP - Windows Shell/User
    "Stacy" <Stacy@discussions.microsoft.com> wrote in message
    news:8D9F1C89-CA54-4B8F-97A2-F0D922B11BFD@microsoft.com...
    > Tech Information:
    > partmgr.sys
    > Stacy
  4. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Ok, I have no idea with a write zeros function is. How do I do that? Also,
    you are suggesting that I try to install 98 and then do an upgrade?
    Stacy
    "Mike Hall (MS-MVP)" wrote:
    > Stacy
    > again..
    > Mike Hall
    > > Tech Information:
    > > partmgr.sys
    > > Stacy
  5. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Sorry, I figured out what the write zeros function is.
    > Stacy
    > again..
    > Mike Hall
    > > Tech Information:
    > > partmgr.sys
    > > Stacy
  6. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Stacy
    I am not suggesting that you load Win 98.. I am suggesting that you
    partition and format the drive using the programs on a Win 98 boot
    diskette.. then when you install XP, accept the option to format NTFS..
    Mike Hall
    news:07FC4E2C-95F6-4C28-8EFF-497F24EBC3A9@microsoft.com...
    > Also,
    > Stacy
    >> Stacy
    >> run
    >> all
    >> procedure
    >> again..
    >> Mike Hall
    >> > have a
    >> > problems.
    >> > a
    >> > it
    >> > I
    >> > am
    >> > Tech Information:
    >> > partmgr.sys
    >> > Stacy
  7. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > computer is
    > motherboard went out and we just replaced that along with new RAM to
    With all due respect Stacy, "new" is irrelevant. Hardware can fail out
    of the box. Troubleshooting needs to be done in a very methodical and
    thorough way. If you haven't tested your RAM, you haven't done
    systematic troubleshooting. You need to eliminate all factors. Things
    to try in your situation:
    1. Test the RAM.
    2. Test the power supply, making sure it is adequate for the devices in
    your computer. This means swapping out the psu for a known-working one.
    3. Test the hard drive.
    4. If the above 3 items test good, try to install the operating system
    with nothing in the computer attached to the motherboard except:
    a. Video card
    b. RAM
    c. The hard drive - only one
    d. The new cd drive - leave the other one unattached to the power
    connector.
    e. The floppy if you have it. If your computer will boot without a
    floppy drive connected, leave it unconnected.
    If the operating system installs correctly, you know that some other
    component was causing difficulty, perhaps causing a short. I had an
    older cd-rom drive that did that and it was very hard to trace down
    that problem.
    Malke
    "Don't Panic!"
  8. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Ok. Tested RAM - tested good. Tested psu - tested good. Now I am ready to
    test the hdd. My question is this. I have the diagnostic program on a disk.
    Can I just put that in my drive and restart the computer? I'm not sure how
    to tell if it will start up from the cd drive. I do have the BIOS set to
    boot from cd drive currently.
    "Malke" wrote:
    > > computer is
    > 1. Test the RAM.
    > a. Video card
    > b. RAM
    > connector.
    > that problem.
    > Malke
    > "Don't Panic!"
  9. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > have a new hdd. I am trying to install xp on it and having nothing
    > but problems. It runs through the set up and then gets so far and
    > says that there is a problem with the set up and installation cannot
    > continue. It says that it could be a damaged disk. The disk is not
    I don't know what your problem is, but if I were you, I wouldn't assume that
    because the disk is brand new, it can't be damaged.
    Like almost every other product, even brand new Windows CDs can be
    defective.
    Or if you mean the HD, not the Windows CD, those can also be defective right
    out of the box.
    Again, I'm not saying that's your problem, just that you shouldn't rule it
    out so quickly.
    Ken Blake
    Please Reply to the Newsgroup
    > I called the manuf. of the hdd and they
    > said it is a windows problem. I am getting a stop error screen with
    > Tech Information:
    > partmgr.sys
    > really starting to piss me off.
    > Stacy
  10. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > of the box.
    I've got to agree, 100% !!!! I've put together many systems, and I
    learned the hard way to ALWAYS ALWAYS ALWAYS test the RAM as the very
    first step. Update the BIOS to latest available, reset the cmos, review
    and set all bios settings to desired values, then test the RAM w/
    memtest86+. Only after at least 1 hour of testing w/ ZERO errors do I
    proceed w/ installing an OS. Even a single error is a problem, do not
    proceed until it is resolved.
    Many "brand new" boxes have issues w/ RAM, where simply swapping sticks or
    slots resolves the issue. I've had boards that simply would not work w/
    one brand of DIMM, but worked just fine w/ another (and the "bad" dimms
    worked just fine in another motherboard).
  11. Archived from groups: microsoft.public.windowsxp.general (More info?)
    ok, ram tested fine. I guess I will have to try the diagnotic program and
    hope it will boot from the cd and run.
    > > of the box.
Hard Drives Windows XP
