Tom's Hardware > Forum > CPU & Components > CPUs > Weird problem, please help
Forum CPU & Components : CPUs - Weird problem, please help
After running Windows for sometime, drag-drop doesn't work (in Windows explorer), can't scroll pages with keyboard in Internet Explorer, in MS Excel sometimes locked drag happens if I right click, no context menu if I right click office assistant (in all MS Office apps). This problem goes away if I restart Windows, but again happens after sometime. I don't have any stability problem or other probs. This is happening since last couple of weeks.
What's wrong?
<b><A HREF="http://geocities.com/spitfire_x86" target="_new">My Website</A></b>
<b><A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig & 3DMark score</A></b>
Sponsored Links
Check for virus, i know it could´nt make sense but i had a similar problem and i found out it was a virus!
Reply to Mask
I've scanned my PC just now with NAV 2002 (with 19/Aug/2003 definations), no sign of virus.
Reply to Spitfire_x86
What version of Windows is this?
Have you done a Windows Update so that you have the latest and greatest Windows bug fixes?
And try to see if it starts happening <i>only</i> after running a specific program. (It could just be someone wrote bad code that is corrupting memory.)
Hey, slightly on topic still but a different line of discussion: Does anyone know of a really kick-arse <i>free</i> (as in <i>not</i> shareware but actual freeware) anti-virus suite for Windows? In an ideal world the open-source community should have come up with something cool by now. :)
<pre><b><font color=red>*** BattleTech - The Crescent Hawks Inception ***</b>
Pilot twenty-ton behemoth robots to save your planet from a
Kuritian invasion force. Now available on the C=64!</font color=red></pre><p>
Reply to slvr_phoenix
I'm using Windows 2000 (SP4 installed). Since Win2000 SP4 is quite recent, there may not be much thing to update. Moreover I wouldn't like to manually update via Windows Update, since I'm using 33.6k dial-up.
I did a clean Windows installation recently, with Win2000 (SP4 integrated) and installed Visual Studio.NET 2003. I can't remember about this problem with Win2000 SP3. Actually I'm not sure which thing is causing problem, since I had 2 big changes in softwares recently. I've never used Win2000 SP4 or Visual Studio.NET 2003 before.
It doesn't happen after running a specific program. Sometimes after using, it just "happens"
Yeah, I've done Windows Update over modem on my PC at home (which varies in connection speed between 28K and 40K) and that's no fun. It's definately an overnight task. :\
Unfortunately running Windows Update is about all that I can think of. Maybe search Microsoft's site for the bug and see if they've addressed it in their knowledge base.
If it helps any I'm running Windows 2000 SP4 here at work and it hasn't had any problems like that. I don't even dare touch .NET though (happily using VC++ 6.0 when I do Windows-specific programming, which isn't often anymore thanks to Python and Qt) so I suppose it's possibly related to that.
But then again I've also done a full Windows Update recently so if it was SP4 that was causing the bug but another update fixed that, then I wouldn't have seen it anyway.
Sorry that I can't be of much help. It's a truly weird problem.
<pre>If you look <font color=purple>The Devil</font color=purple><font color=red>®</font color=red> straight in the eye and only see yourself then you must be standing in front of a mirror.</pre><p>
I've checked Windows Update, only few security updates to install. My problem doesn't seem to be security problem, so I didn't download them.
BTW, I haven't installed full VS.NET, only VB.NET.
Disk defragmentation?
Sufficient swap space?
The loving are the daring!
Reply to Flinx
I defrag very frequently.
I've 384 MB minimum (768 MB max) swap file. My system never goes out of virtual memory
There are 826 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
