G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Checked continuity with no issues, Upper playfield is getting between 9 to
21 volts. Still no upper G.I. playfield lights or Bumper lights. No flashers
under the plastics. However, All switches, lights and flashers under the
upper playfield work. Swapped relay board with the one on the backbox. No
difference. Backbox lights still work but nothing on the upper playfield.
Any suggestions??
Thanks again
Kevin
Any suggestions??
Thanks again
Kevin
