BSD diverter blade
Add a reply
 Word :   Username :
Bottom
Author
 Thread : BSD diverter blade
More Information
Archived from groups: rec.games.pinball (More info?)
Hello,
I'm trying to find out how the diverter blade behind the coffin should be
mounted. I took it off while taking out the main ramp but don't know how to
put it back :(
Currently when shooting the left ramp my ball is always going to the castle
so I assume something is wrong.
I looked around on the net and found different pictures where the blade is
in both directions... Please provide pictures of how it should be done and
how the beginning position is.
Thanks,
-Peter
Related Pr oduct
More Information
http://www.flippers.be -> newbie guide - > glossary
there's a picture of the diverter in default position..
This is not a diverter which moves left/right but up and down !
Default it's in the up-position so a pinball can pass underneath it.
When the coil is activated the diverter is pulled down so it diverts
the ball.
Aeneas.
More Information
I checked out the picture ; is the diverter touching the plastic of the
outside ramp in its upmost position ?
-Peter
<averhe@hotmail.com> wrote in message
news:1121683671.687917.213720@g49g2000cwa.googlegroups.com...
> the ball.
> Aeneas.
More Information
The edge of the diverter will be barely touching the outside/top edge
of the ramp when in the up position.
The smooth concave part of the diverter faces the left side of the
playfield.
The two bolts on the diverter go into the up/down post and are secures
with the small nits on the back. The bolted edge of the diverteer is on
the side of the ramp closest to the player with the other end pointing
toward the backbox.
http://www.myhomegameroom.com/pinb [...] s/bsd2.jpg
Hope that helps,
-cAyle
More Information
How do you get the up/down post in the top position ?
When I pull it up it falls down again immediately...
-Peter
"Cayle George" <caylegeorge@gmail.com> wrote in message
news:1121697268.989918.230250@o13g2000cwo.googlegroups.com...
> playfield.
> toward the backbox.
> Hope that helps,
> -cAyle
More Information
On Mon, 18 Jul 2005 14:45:04 GMT, "pninja005" <pninja005@hotmail.com>
>-Peter
you probably lost a spring ?
Aeneas.
More Information
The blade is normally "up" in a resting position when the machine is
off - yes there should be a spring that holds it in the up position.
The coil pulls it down when it fires.
I think bay area amusements has these springs if I remember correctly.
More Information
That's a 10-399 Compression Spring
BAA does have these for 75 cents.
news:1121703553.861914.223080@z14g2000cwz.googlegroups.com...
More Information
I checked the up/down post very closely and I think a little piece is
missing :(
Ref. BSD manual page 2-32 (A-16265 Up/Down Post Assembly)
The problem I have is that number 3 (A-16146) is not stuck anymore and falls
down. I noticed this piece has a small tube hole, I assume some little piece
of metal must be inserted there? Anyone knows what's needed to insert ?
-Peter
"John Wart, jr" <johnwartjr@johnwartjr.com> wrote in message
news:35KdnVI5tJmf_EHfRVn-sg@comcast.com...
Add a reply
Google Ads
News
HP rolls out blade workstations
Published on November 30, 2006
HP has rolled out the industry's first blade workstation which stores the computer safely away in the datacenter closet. The ProLiant Blade Workstation Solution is stacked vertically in blade chassis cabinets and several dozen can be placed in a standard 19" wide server rack. Read more
First Cell-powered computer ships
Published on January 10, 2006
The first product based on IBM/Toshiba/Sony's Cell processor has shipped, reports Mercury Computer Systems. Mercury's Cell Technology Evaluation System (CTES) is a 470-pound behemoth with one or two dual-Cell blades running Linux. It targets defense, medical, and industrial inspection markets. Read more
Dell Goes Against HP, IBM With New Blade Servers
Published on January 21, 2008
Dell has updated its blade server portfolio and claims that its latest M-series eclipses its competition in power consumption and power efficiency. Read more
Intel launches "Sossaman" dual-core blade server processor
Published on March 14, 2006
Intel announced the third variant of its Yonah processor core. Next to Core Duo and Core Solo, the company now offers the blade server CPU Xeon LV, formerly code-named Sossaman. The chip is Intel's first low-voltage dual-core processor and promises at least twice the energy efficiency of preceding single-core Xeon processors. Read more
Latest Reviews & Articles
Shuttle's X27: Can Atom Handle Vista?
Published on October 08, 2008
In the horsepower race between Intel’s and AMD’s quad-core chips, the Atom processor is an everyday hybrid. Shuttle took it and created a pint-sized small for factor box. Is it powerful enough to be your daily-use desktop, though? Read more
Do New Drivers Really Boost Performance?
Published on October 07, 2008
How much extra performance can you get from a simple graphics driver update? And what sort of gaming gains can you expect from a high-end graphics card when you overclock your CPU? Read more
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
