Tom's Hardware > Forum > Systems > Dell > Adding a Sound Card
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a 400SC system and would like to add a sound card...
Do I need to turn the sound option OFF in the BIOS, and delete anything in
the Device Manager, before fitting the card & installing the software? Or
just fit & install the card and let the new software take care of
everything?
Thanks.
Sponsored Links
"EB" <ebelletty@sbcglobal.net> wrote in message
news:dGAmc.5920$xG.4648@newssvr27.news.prodigy.com...
> everything?
> Thanks.
It's likely that BIOS will disable the integrated sound automatically.
While I don't know the 400SC, I would likely install the sound card software
first noting the location of the driver files, then power down and install
the card - then reboot and point Windows ( if you're in fact using Windows)
to the .inf files.
You could go to the trouble of removing traces of the down sound from device
manager, but that may not even be necessary unless you'd just prefer it.
Stew
Reply to Anonymous
When I added a pci soundcard to my 400sc,I first disabled the on-board sound
in device manager.Then installed the sound card as per manufacturers
recommended method.
> everything?
> Thanks.
Reply to Douglas
"Douglas" <.> wrote in message news:<A5mdnZR1itkQngbdRVn-uQ@centurytel.net>...
> recommended method.
> > everything?
> > Thanks.
On any Dell computer I have worked with you can disable on board
sound in the bios. You will not have to disable in windows
if you do this.
Dave
Reply to David
Well,I have the 400sc,and there is NO NEED to turn it off in the bios!Either
just disable it or uninstall the soundmax drivers if you have installed
them.Then install your card!
"David" <davids165@juno.com> wrote in message
news:4feda6e.0405070556.e6afa9e@posting.google.com...
sound
> > recommended method.
anything in
Or
> > > everything?
> > > Thanks.
> if you do this.
> Dave
Reply to Douglas
There are 1286 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
