Sign-in / Sign-up
Dual Monitor TV. One monitor has no sound
  • HDTV
  • TV
  • Dual Monitors
  • Computer
  • Home Theatre
Last response: in Home Theatre
April 25, 2012 10:44:20 PM
Hi just need your advice having trouble for days. i connected my 2 HDTV to my computer. One tv works perfect but the other tv doesnt have a sound only video output.
when i try to play dvd movie the other tv has no sound. supposed to be they are synchronize. By the way im using HDMI cables to connect the tvs to my computer.
What could be the problem? need advice please.. thank u
More about : dual monitor monitor sound
a b x TV
April 26, 2012 12:31:44 AM
What graphics card do you have installed?
-Wolf sends
m
l
April 26, 2012 3:47:00 AM
its ASUS geforce8400 512mb
m
l
a b x TV
April 26, 2012 10:17:23 AM
Ok. Well, I've never seen an ASUS Geforce 8400 with two HDMI outputs. Neither DVI nor VGA carry an audio signal, so it makes sense that you're only getting audio over to only one HDTV.
If you do have a card that has two HDMI outputs, then I suspect there are two different audio controllers and you can only use one at a time.
-Wolf sends
m
l
a b x TV
April 26, 2012 5:56:07 PM
Windows should not send the same sound source to two devices. HDMI is even stickier with it's HDCP protocalls. if both are hoooked up with HDMI, you can go into your sound control panel, and select which set you would like to play the audio through.
m
l
