problem installing xp inc sp2
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi
Whenever I try and install windows xp inc sp2 onto a RADI 0 array formatted
with 32kcluster after the initial file copy process the system reboots and
gives a disk read error yet when using XP sp1 the install works fine.
tried pro and home and same on both also tried various versions of the sata
driver and that hasn't helped either.
motherboard is MSI KT800 neo
AMD 64 3000
Maxtor 120GB hd x2
More about : problem installing sp2
This is a clean install?
i.e. you deleted and created partitions etc using wincd
You installed sata drivers from floppy during the installation process?
You installed into a 'bare' system?
i.e. minimum hw
Your bios boot order is set correctly?
"Nick Vidamour" <nick@mesha64.plus.com> wrote in message
news:u$XlNkvqFHA.1032@TK2MSFTNGP12.phx.gbl...
> Hi
formatted
sata
> AMD 64 3000
> Maxtor 120GB hd x2
clean install in some ways yes
created partitions using a seperate hard drive so that can format it with
32k cluster size and then took that dive out
(this problem doesn't appear when creating the paritions and formatting
within the installation but then i'm stuck with a 4k cluster size and get
the same error if using partition magic to change the cluster size"
installed sata drives from floppy fine
bios order set correctly and min hw
"DL" <dl@spoofmail> wrote in message
news:%23YfP1uvqFHA.904@tk2msftngp13.phx.gbl...
> i.e. minimum hw
>> Hi
> formatted
>> and
> sata
>> AMD 64 3000
>> Maxtor 120GB hd x2
Nick,
If I may ask, Why do you want the cluster size at 32K ?
Maurice N
MVP Windows - Shell / User
> with 32k cluster size and then took that dive out
> formatting within the installation but then i'm stuck with a 4k
> cluster size and get the same error if using partition magic to
>> process?
>> i.e. minimum hw
>>> Hi
>>> formatted with 32kcluster after the initial file copy process the
>>> system reboots and
>>> fine.
>>> the sata driver and that hasn't helped either.
>>> AMD 64 3000
>>> Maxtor 120GB hd x2
Related ressources
i might just simply ignore the 32k cluster altogether as i'm only using the
system as a general user and with some tests i've performed cannot visially
see a difference in performance between cluster sizes.
as a side note to this though is, what is the best set up for stripe and
cluster size
should they be the same e/g 32/32 or should cluster be larger or smaller
news:%23JYEt0vqFHA.2244@tk2msftngp13.phx.gbl...
>> i.e. minimum hw
>>> Hi
>> formatted
>>> and
>> sata
>>> AMD 64 3000
>>> Maxtor 120GB hd x2
think its a case of reading what you think is right
basically most people say that a larger cluster size increase speed due to
less head movement, but visually i can't see a difference.
also using a raid array they says it best to have either a matching or 1/2
size cluster.
don't know which is correct tbh
"Maurice N ~ MVP" <maurice@mvps.org> wrote in message
news:uWXksAwqFHA.2604@TK2MSFTNGP14.phx.gbl...
Nick,
Maurice N
>> process?
>> i.e. minimum hw
>>> Hi
>>> system reboots and
>>> fine.
>>> AMD 64 3000
>>> Maxtor 120GB hd x2
For efficiency of access / reads, etc, you run Disk Defragmenter or an add-on utility like Perfect Disk to keep data files physically contiguous. So forget the larger cluster size on that topic. In addition, when you have lots of very small files, a 32K cluster size is going to be very wasteful.
I think you need to start all over and install XP fresh, and let it create the partition.
Maurice N
> due to less head movement, but visually i can't see a difference.
> or 1/2 size cluster.
> Nick,
>>> process?
>>> i.e. minimum hw
>>>> Hi
>>>> system reboots and
>>>> fine.
>>>> AMD 64 3000
>>>> Maxtor 120GB hd x2
thats what i'm going to do really, just been making the xp installation with
all updates and hotfixes etc...
news:uk%2350qwqFHA.4072@TK2MSFTNGP09.phx.gbl...
the partition.
Maurice N
> Nick,
>>> process?
>>> i.e. minimum hw
>>>> Hi
>>>> system reboots and
>>>> fine.
>>>> AMD 64 3000
>>>> Maxtor 120GB hd x2
Ask the community
