G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello!
After booting my XP SP2 today i encountered massive problems:
1) All desktop icons changed to default windows icon
2) Windows could not start any exe-files
3) start menu empty
4) instead of "my computer" and "network neighb." the icons are just called
"Folder"
Ok. After a bit of searching i managed to fix the exe and lnk file
associations. All other file associations are still missing (pdf and so on).
Also the start menu is still empty.
Then i checked the folders and the registry. All program information and
file ass. information is still in the registry! Folders are still existing
with all my shortcuts in them. The registry does not look corrupt in any
way - the shell/folder-entry is correctly pointing to my users start menu
folder. Nevertheless it seems as is windows is not executing a certain part
of the registry. System is slow as if dma support was not loaded - could be
a hint thtat also some driver/hardware connected registry settings are
ignored although they are in the registry.
In explorer windows and IE windows there is no field to input folder names
or web addresses. Some part of the GUI seems not to be loaded.
Has any of you some hints to fix this system without reinstalling? Somehow I
believe that repairing a single faulty registry entry could do the trick and
enable windows xp to load to whole registry again - incl. file associations
and so on.
Help would be appreciated! Thanks in advance.
Bye Oliver
Hello!
3) start menu empty
"Folder"
and so on.
Bye Oliver
