Solved
Shurtdown problem
will Malware create shutdown problems ....
4 answers Last reply Best Answer
More about shurtdown problem
  1. More probably the power supply or the heating.
  2. Best answer
    It can do, have a scan of the system with malware bytes.
    Also do a check of the HD disk make sure there is not a problem with the file system of it. And do a virus check also.
  3. Best answer selected by fleurhema.
  4. i did, i removed malware . now and cleaned it and i also used combafix .. thanks for ur reply
Malware Shutdown Windows 7
