Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello,
I was trying to re-format my computer, using the Windows XP Professional
startup disk. I've done this before without problems, however this time I
begun to encounter problems with the partition table. I removed all
previously used partitions and created a new one to install XP Pro onto,
everything went well with the NFTS formatting until the restart, once
restarted it went to a black screen saying "Invalid Partition Table".
I have been able to complete the installation by pressing F8 on restart,
then selecting the CD Drive and then not doing anything when it asks to boot
from CD, however, after completing the installation it requires a restart and
the problem occurs again.
I can continue to boot from CD, though I'd much rather not have to.So I've
attempted to reformat the partitions several times with no avail and also
tried using PartitionMagic when the computer was running from the XP disk.
Any support would be appreciated as I do not see why I should have problems
upgrading from XP Home to XP Pro. Just to note, I've also tried installing
with the other XP Pro disk we have in the house, and my old XP Home disk- The
same error occured each time.
Thankyou,
Andrew Milne
Please Note: I've looked at every partition guide, so please don't post
links to sites that will just tell me how to create partitions, I know how
to... And have done so properly, it's just not working
"Andrew Milne" <andrewmilne@iinet.net.au.(nospam)> wrote in message
news:8DA05405-B075-45BA-89C1-0E9BA765D5B4@microsoft.com...
> Hello,
boot
and
problems
The
> Thankyou,
> Andrew Milne
Your post does not make it clear how you deleted the
old partitions, nor does it say if you're happy to re-install
WinXP. Here is what I would do, in this order:
1. Boot the machine with a Win98 boot disk (www.bootdisk.com).
2. Run this command to restore the Master Boot Record: fdisk /mbr
3. Remove the boot disk, then reboot the machine. Problem fixed?
4. If not, reboot the machine with the Win98 boot disk.
5. Run fdisk.exe, then delete all existing partitions.
6. Create a primary FAT32 partition of 10 or 20 GBytes.
7. Create a logical FAT32 partition to take the rest of your disk.
8. Reboot with the Win98 boot disk.
9. Type this command: format c: /u /s /v
10. Remove the boot disk, then reboot the machine. Problem fixed?
11. If yes, install WinXP. If no, try the advice given by other respondents.
If fdisk refuses to delete some partitions, use delpart.exe instead
(http://www.russelltexas.com/delpart.htm).
Yeah, I want to install XP Professional on to my computer.
I removed my partitions originally with the XP Setup Disk when it gets to
the Partition stage, and seeing as I was having problems there, I removed
some using PartitionMagic.
Okay, to do the second option, all I do is download a Windows 98 boot from:
http://www.bootdisk.com/bootdisk.htm
Then put the file that I download onto a floppy, and put it into my PC and
boot it?
Is the FDisk and such all in the boot file I download? Sorry for my
ignorance, I really don't understand alot about computers at this level.
> > Hello,
> boot
> and
> problems
> The
> > Thankyou,
> > Andrew Milne
fdisk.exe is included with the Win98 boot disk that you
download from www.bootdisk.com. Have a look for yourself!
news:25F2AB77-E440-42B5-939B-E384D2980875@microsoft.com...
> boot it?
> > > Hello,
Professional
time I
onto,
restart,
to
> > boot
restart
> > and
I've
also
disk.
> > problems
installing
disk-
> > The
> > > Thankyou,
> > > Andrew Milne
post
how
respondents.
Alright, I did all the things you suggested. Though, on restart the same
problem still occurs.
Any other advice?
> from:
> > boot it?
> > > > Hello,
> Professional
> time I
> onto,
> restart,
> to
> > > boot
> restart
> > > and
> I've
> also
> disk.
> > > problems
> installing
> disk-
> > > The
> > > > Thankyou,
> > > > Andrew Milne
> post
> how
> respondents.
Please describe exactly what you see at Step 10.
With "exactly" I mean the verbatim messages that
appear on the screen.
news:A84AF9B6-0217-428E-B40C-0FA560843D68@microsoft.com...
> Any other advice?
to
removed
> > from:
and
> > > boot it?
level.
> > > > > Hello,
> > Professional
> > time I
all
> > onto,
once
Table".
> > restart,
asks
> > to
> > > > boot
> > restart
> > > > and
to.So
> > I've
and
> > also
XP
> > disk.
> > > > problems
> > installing
Home
> > disk-
> > > > The
> > > > > Thankyou,
> > > > > Andrew Milne
> > post
know
> > how
> > respondents.
It says, just as it did before, "Invalid Partition Table"
I've completely formatted the drive using several different programs. There
is 0 partitions, yet it's still buggery. I think the drive might be
permenantly screwed.
> > Any other advice?
> to
> removed
> > > from:
> and
> > > > boot it?
> level.
> > > > > > Hello,
> > > Professional
> > > time I
> all
> > > onto,
> once
> Table".
> > > restart,
> asks
> > > to
> > > > > boot
> > > restart
> > > > > and
> to.So
> > > I've
> and
> > > also
> XP
> > > disk.
> > > > > problems
> > > installing
> Home
> > > disk-
> > > > > The
> > > > > > Thankyou,
> > > > > > Andrew Milne
> > > post
> know
> > > how
> > > respondents.
If this was my machine then I would take these steps:
2. Run delpart.exe to delete ALL partitions.
3. Boot the machine with your Win98 boot disk.
4. Run this command to restore the Master Boot Record: fdisk /mbr
5. Run fdisk.exe to create new partitions.
7. Reboot with the Win98 boot disk.
8. Type this command: format c: /u /s /v
9. Remove the boot disk, then reboot the machine.
10. If this did not work then I would temporarily install the disk
in some other Win2000/XP PC, then delete and recreate all
partitions.
After this I have no more suggestions. Sorry.
news:9562C1D6-E779-4291-807F-A258DB0D7116@microsoft.com...
There
same
> > > Any other advice?
gets
> > to
> > removed
boot
> > > > from:
my PC
> > and
> > > > > boot it?
my
> > level.
message
> > > > > > > Hello,
> > > > Professional
this
> > > > time I
removed
> > all
Pro
> > > > onto,
restart,
> > once
> > Table".
on
> > > > restart,
it
> > asks
> > > > to
> > > > > > boot
requires a
> > > > restart
> > > > > > and
have
> > to.So
> > > > I've
avail
> > and
> > > > also
the
> > XP
> > > > disk.
have
> > > > > > problems
tried
> > > > installing
> > Home
> > > > disk-
> > > > > > The
> > > > > > > Thankyou,
> > > > > > > Andrew Milne
don't
> > > > post
partitions, I
> > know
> > > > how
/mbr
disk.
fixed?
> > > > respondents.
instead
I think deplart is a great way to go.
Fdisk and the winxp setup utility sometimes just don't do the job if there
are other types of partitions(like ext2) or if a third party app like
partition magic has been used.
I am actually a huge fan of the gdisk utility that comes with ghost. I have
had great success with its /diskwipe that cleans off the whole surface of
the disk and /mbr switch.
I don't think this disk is hosed, it just needs a DoD style wipe.
Manny Borges
MCSE NT4-2003 (+ Security)
MCT, Certified Cheese Master
The pen is mightier than the sword, and considerably easier to write with.
-- Marty Feldman
"Pegasus (MVP)" <I.can@fly.com> wrote in message
news:%23P1Q876qFHA.1204@TK2MSFTNGP15.phx.gbl...
> partitions.
> There
> same
>> > > Any other advice?
> gets
>> > to
>> > removed
> boot
>> > > > from:
> my PC
>> > and
>> > > > > boot it?
> my
>> > level.
> message
>> > > > > > > Hello,
>> > > > Professional
> this
>> > > > time I
> removed
>> > all
>> > > > > > > XP
> Pro
>> > > > onto,
> restart,
>> > once
>> > Table".
> on
>> > > > restart,
> it
>> > asks
>> > > > to
>> > > > > > boot
> requires a
>> > > > restart
>> > > > > > and
> have
>> > to.So
>> > > > I've
> avail
>> > and
>> > > > also
> the
>> > XP
>> > > > disk.
> have
>> > > > > > problems
> tried
>> > > > installing
>> > > > > > > XP
>> > Home
>> > > > disk-
>> > > > > > The
>> > > > > > > Thankyou,
>> > > > > > > Andrew Milne
> don't
>> > > > post
> partitions, I
>> > know
>> > > > how
> /mbr
>> > > > > > fixed?
> disk.
> fixed?
>> > > > respondents.
> instead
There are 971 identified and unidentified users. To see the list of identified users, Click here.
