Well. Here I am again. A while back I had originally thought my motherboard was bad, but when I switched graphics cards, all seemed well. Everything was working fine until a couple days ago. We recently setup a wireless network in my house. My computer had a 2nd network card installed so I could maintain the IP address and I'd just share the connection through the other NIC card. I know it sounds like a bit much, and I could port forward and all that.. but I dont feel like setting up ports everytime I try to play a new game.
Anyways - heres the new problem. Yesterday my wife came in the computer room and switched the wrong switch for the light. The switch she had press was to the power of my computer. This cut it off. When I got home from work I saw this and assumed all was well. I turn on my computer screen and its blank, but I could hear the hard drives spinning and so forth. So I hit the power and it does nothing. Then I hold the power button for 5 seconds forcing a shutdown. Turn it on, the cd drive spins, hd spins.. but no post beep.
I then reset cmos and turn on and everything was fine.
Today I played it for a few hours, then left for work at 4:50. I get home at 9:30 and go to play but it was acting up. First thing I noticed... the clock read 6:11 when the time was actually 9:38. So I change the clock, boot up warcraft 3 and notice its running too fast, we're talking 4x as fast as normal. So I shut it down, then restart windows. Similar to yesterday, it goes to post.. but no beep (and of coarse this means its stuck cause it wouldtn do anything else). So I reset cmos again. Nothing. Before admitting defeat.. I try once more and then it lives once more. Could someone PLEASE tell me what in the blue hell is going on? Is it my motherboard or do you think its something else?
heres my current specs:
ABIT ICG-7 MB
2.4c P4
512 3200 400mhz Ram
2 HD (one is dedicated to vmem and backup files)
2 NIC cards (one being onboard)
SB Audigy (with Audigy drive)
Floppy
Geforce 4 TI 4200
400 Watt PS
LITE-On Burner
Running Windows Xp Pro with Sp1
also - I've run memtest till I was blue in the face. The ram has/had no errors at all.
Thanks
Onslaught
ABIT ICG-7 MB
2.4c P4
512 3200 400mhz Ram
Floppy
Geforce 4 TI 4200
400 Watt PS
LITE-On Burner
Thanks
Onslaught
