Flickering lcd monitor repair
Hello,I have a Compaq Presario F560US - the LCD monitor went blank/black or flickers every so often. It works perfectly with a external monitor. My research so far have led me to replacing the inverter and LCD screen/w new backlight. But this didnot fix the problem. Don't know what else to try. Any fresh ideas... please share...would be appreciated greatly.
7 answers Last reply
More about flickering monitor repair
  1. If a new inverter or LCD didn't work, I suspect that it may be an issue with the GPU. It may be damaged due to heat or simply shot. Also, have you checked all of the connections, wires, etc...?
  2. A good output on an external screen generally indicates a good GPU.
    Depending on what you mean by flicker, this could be a driver issue. Does the problem persist in BIOS/Safe Mode?
    Does the flickering stop when you apply pressure to the back of the screen in any locations or around the LCD bezel?
  3. Agree with comment on good o/p on external screen = indicates good GPU.
    Flicker = the screen comes and goes until it's blanked out or black. It stays black most of the time.
    I've tried pressure around the screen and bezel points to no avail. After replacing LCD and inverter -- also tried wiggling the connecting wiring. Was thinking a shortage existed some place in the wiring. This also didnot make a difference. All cables are connected properly - that is from the screen(LCD) point. I have not looked or checked from the system(where all the components is housed) point.
    Thanks for your your feedback.
  4. If that's the case, (assuming the parts you got were good ones) I'm out of ideas for a hardware issue. Check if the problem still occurs in BIOS/ safe mode.
  5. i also have the same problem... flickering with lines occuring in startup and bios... tried wiggling the wires to see if it reacts... but nothing happens still the same... also tried replacing the lcd and still the same... but it if i connect it to external display it works fine... darn it... :( anyhow... am about to reheat the gpu with a heatgun and see if it works...
  6. I have a similar problem but it usually can be temporarily stopped using pressure on the corners of the bezel and it works fine with an external monitor? does the fact that I can occasionally deter the problem by putting pressure on a corner of the bezel mean anything?
    ohh darn its been a year... yeah... i did the same thing before that whenever i put pressure it works but when u let out that pressure it freezes and will not work again... anyways i tired reheating the GPU and works like a charm... :)
Presario LCD Monitor External Monitor Laptops
