Help on new system....
Whats up? Im about to upgrade my PC and need a few suggestions. Here is what I had planned on getting
Athlon XP 2500
ATI Radeon 9800 Pro 128MB
ASUS A7N8X Motherboard
2x256MB PC2700 OCZ RAM
WD 60GB Hard Drive 8MB Cache
Here is what I need to know
1.Will the A7N8X unlock my XP2500 for me so I can overclock
it? Can I go with FSB400?
2.Just how much faster is a 9800 Pro than a 9700 Pro? Can a 9700 Pro overclock to 9800 Pro speeds? How soon will the next Radeon be out?
Any suggestions on making this cheaper while keeping the same or better performance will be appreciated , even if it means going P4 or NVIDIA. Thanks. ( I WILL OVERCLOCK)
What was used to program a programming program?
2 answers Last reply
More about help system
  1. 1. A7N8X would unlock your Barton, but I read it somewhere saying that new Barton has different packaging and is factory locked which prevent it from unlocked, even on nForce2 chipset. If yours Barton is unlocked, 200MHz FSB (400MHz DDR) is no sweat. I've seem some people make it to 250MHz (that's 500MHz DDR!).
    2. The difference between 9800P and 9700P is not only the clock speed. The hardwired features llike Pixel Shader 2.1 support and infinite pixel rendering will not able to achieve on 9700 as they are two different core R300 and R350. R360 is still in the mist though...
    If you want to overclock better, I suggest you get either Epox 8RDA+/8RDA3+ or Abit NF7/NF7-S, there are cheaper than Asus and overclock better. And I would really suggest that you get at least PC3200 RAM because PC2700 RAM will certainly limit your overclockability for sure. Corsiar PC3500 and Kingston HyperX PC3500 are good candidate for overclocker. Hope this helps :)
    Me fail English? That's Unpossible!
    <A HREF="http://www.anandtech.com/mysystemrig.html?id=22996" target="_new">My System Rig</A>
  2. I have the a7n rev 1.06 and a 2500 running at 2.25, with a stock fan and voltage. I have heard that the newer 2500s can oc higher but I haven't really pushed mine. Make sure the board is rev 2 as the fsb is more stable above 200.
CPUs Overclocking
