Archived from groups: microsoft.public.windowsxp.general (More info?)
mMost of my software is now crashing and iy all seems to relate to NTDLL.DLL
this is causing me some distress as I can't even reload XP Home as it came
with my PC alreadt loaded with just a Rescue ddisc which SP2 has invalidated.
The dump I get fro Dr Watsons is below, I hope someone can help me.
Bob
Microsoft (R) DrWtsn32
Copyright (C) 1985-2001 Microsoft Corp. All rights reserved.
*----> System Information <----*
Computer Name: BOBNEUMANN
User Name: Bob Neumann
Terminal Session Id: 0
Number of Processors: 1
Processor Type: x86 Family 6 Model 10 Stepping 0
Windows Version: 5.1
Current Build: 2600
Service Pack: 2
Current Type: Uniprocessor Free
Registered Organization:
Registered Owner: Bob Neumann
On Sun, 28 Aug 2005 13:28:01 -0700, "Bob Neumann"
>Bob
Try changing this in the c:\boot.ini
Hi Greg,
I tried this but it didn't work.
Bob
> >Bob
> /fastdetect /something=something
> /fastdetect /NoExecute=AlwaysOff
> This may or may not work.
> Greg Ro
How does sp2 invalidate the restore cd?
I thought you just stick it in and reboot.
backup your data you want to keep.
Get a windows 98se boot disk from http://www.bootdisk.com
Note if file system is NTFS
You will need to use FDISK*
delete the partition.
If it Fat32 you can start here
Reboot with floppy
Then Format the Drive C
Now remove floppy
insert the restore cd.
Reboot
(*Just in case your system has a hidden restore partition-just make
sure you only delete the activate partition)
If you don't have a floppy Drive-you can use windows 98 setup cd.
Choose boot from cd Choose boot with system with cd-rom support.
It will create a virtual drive A Fdisk will be on Drive a: Format
will be located on the cd drive in the folder win98
