G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
My left flipper on my STTNG fires multiple times when the flipper
button is engaged and released. There is only one flipper on this
side. The coil also makes a noticable hum (not actually a hum, but a
real weird noise) when you let off the button after holding it for a
few seconds. Now with this flipper problem the game is also starting
to occasionaly reset, which it has never done before. All of this
started happening after moving the game. I think the extra flips are
do to the plastic piece that the flipper pushes away from the "U" optos
not being in the right spot, but the funny sound from the coil, is
something I have never heard before. Is it most likely a bad coil or
is there something else that could be causing the noise? I have
checked and the EOS switch is working. Any help or suggestions would
be greatly appreciated.
Mike
Mike
