Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Inspiron 1525 lcd problems
Forum Laptops & Notebooks : General Discussion Inspiron 1525 lcd problems
Hello,
I have a DELL 1525 laptop and the LCD started to go dim, almost completely black this morning.
I was able to shut the lid and open it again and the screen would be bright again but it only lasts for a few mins.
Is there a way to tell if I need a new LCD or if it is something else? I have heard the inverter can go bad on these laptops too - the replacement screens are cheap enough but i dont want to waste $$$ on it if it is something else.
Thanks!
Reply to sanjo
sanjo wrote :
Hello,
Thanks!
I do apologize if this has been brought up before, I searched the best I could and didnt find anything related to the specific question about the LCD.
Reply to sanjo
Sounds like the illumination for the screen -- you can check that by shining a torch on the screen -- if you can see something on the screen it's the fluorescent backlight or its power circuit.
Reply to Anonymous
Thanks, I can see the screen like that, is there any way (aside from buying a new LCD screen) to test if its the screen or the circuit?
Reply to sanjo
It's really a job for a repair guy, just dismantling a laptop is an adventure if you haven't done that model before.
I hesitate to unless I am cannibalising two machines -- so wrecking the case of the donor machine doesn't matter.
Reply to Anonymous
Ugh - well I am pretty tech savy when it comes to tinkering. There is a little local store I could take it too but I dont think I woul dhave aproblem with a LCD replement. I had to do a mobo swap in my DV9000 last year :)
One thing I have noticed is.... When it goes dim I can close and open the lid and the screen comes back for a few mins. Does that solve anything in the way of narrowing it down? Meaning backlight,inverter or circuit?
Reply to sanjo
I found a certified DELL 1525 inverter for $8 so I'm going that route first, rather then spend $100 on the LCD (which I think is fine) if not, it's only $8 and if it is, I saved myself $100.
Reply to sanjo
sanjo wrote: "When it goes dim I can close and open the lid and the screen comes back for a few mins. Does that solve anything in the way of narrowing it down? Meaning backlight,inverter or circuit?"
What's probably happening is closing the lid switches off power to the screen's lighting (to stop it overheating in normal use). When you open it. power is restored and your screen lights up until the faulty component (possibly a capacitor) is affected.
Reply to Anonymous
There are 1995 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bios passwort vergessen laptop acer Extensa 5220
By Brett928S2, 2 hours ago:
Hi :) We are NOT allowed to help with passwords here at Toms... All the best Brett...
Best offers
Top experts
