Archived from groups: rec.games.pinball (
More info?)
I had alot of trouble with my protectors also on this game. You're probably
going to have to bend the scoop up somewhat . . . to make room . . .
Kerry Stair
Mantis Amusements "Its all about Pinball"
"Gerry Manis" <gerrymanis@gmail.com> wrote in message
news:1121964379.410404.209570@g14g2000cwa.googlegroups.com...
> Hi, all.
> I'm working with Cliffy to create hole protectors for JP. The samples
> he has sent me are getting very close! There remains one issue, which
> I hope the group can help with.
> There are two scoops on the middle left of the playfield on JP. They
> are called the Control Room and the Bunker. Under the playfield, these
> two scoops are connected, so that if the pinball goes in the Control
> Room scoop (right side), it rolls left, and is ejected from the Bunker
> scoop (left side). These two holes get the most damage on the game,
> due to their close proximity to the flippers.
> When I test fitted the Bunker protector, I was surprised to find that
> the pinball won't fit down the hole! At first, Cliffy and I thought
> that my scoop had been damaged, and bent down. This turns out not to
> be the case, as it looks like the scoops are designed at two different
> heights.
> After looking at the problem further, I found that the problem wasn't
> the height of the scoop, but rather how the Bunker scoop is mounted in
> the hole. At least on my game, the Bunker scoop is mounted such that
> the metal of the scoop isn't touching the back of the hole. The entire
> assembly is rotated slightly, so that the entire two scoop assembly is
> mounted at a slight angle from what the holes would suggest.
> ...After that long-winded explaination, if you're still with me, I'd
> like a few JP owners to check two things for me (and Cliffy), and post
> your results here:
> 1) Is there a slight difference in the height of your two scoops? It
> looks like the Bunker scoop is about a 1/16th of an inch shorter than
> the Control Room on mine.
> 2) If you look close, is the entire assembly mounted at an angle to
> the holes? Is the Bunker scoop correctly pushed all the way back in
> it's hole, or like mine is it mounted slightly forward?
> It's somewhat trivial to remove the assembly (3 wood screws), patch the
> existing wood screw holes, and re-mount the assembly in the correct
> spot for me, but if ALL JPs have the same problem, it might affect the
> viability of completing the project. (I hope it's just mine!)
> Thanks,
> Gerry Manis
