Will these speakers work on this receiver?
I currently have a 4-5 year old sony home theater system. It came with a receiver and all the required speakers for a 5.1 setup. Now my question is will the speakers work with a newer receiver. Here is a link for my current system.
http://esupport.sony.com/US/perl/model-home.pl?mdl=HTDDW700&LOC=3&tab=howtoTab
Here is a link to the receiver that I want to get.
http://www.amazon.com/Onkyo-TX-NR509-Channel-Network-Receiver/dp/B004O0TRCO/ref=cm_cmu_pg__header
I know that the Onkyo receiver supports 6-16 ohm impedance and the speakers that came with the sony setup use a 6 ohm impedance. My biggest question is can I the sony speakers without a possibility of them blowing out because of overload etc.
Any help would be appreciated.
1 answer Last reply
More about will speakers work receiver
  1. 6 ohms to 6 ohms is a match
    blowing out means what?
    too much heat on the voice coil because of too much electricity going to the voice coil.
    you have an RMS value and a peak value.
    if either one is too high, the coil will get hot.
    how hot is too hot? ... ask the voice coil or the manufacturer of the voice coil.
Sony Speakers Home Theatre Audio
