Yes No
Ads
Power Inverter
Forum Laptops & Notebooks : General Discussion Power Inverter
I just started using a Tripp Lite 300 Power Inverter and used a Dell Latitude 810 with it.
Not sure if this is coincidince or not but now the laptop wont charge with the AC Adapter anymore, even if plugged into regular AC plug at home or office. PC states it does not recognize the type of AC Adapter and will work slower and battery will not charge.
Is it possible that the Tripp Lite inverter did something to this AC Adapter?
Reply to texray00
Possibly. What voltage output does the PSU give?
------------------------------ Desktop | i7 920 @ 3.8 | P6T | 24GB DDR3-1600 | 2x5870 CF | 3TB total | Corsair 850TX | HAF932 | XigDK | 2x24" 1920x1200 | Win 7 x64
Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17" | Win 7 x64
Reply to frozenlead
Here are the Specs for the Tripp-Lite
Model: PV375
Output Power(cont): 375 Watts
Output Pwere(peak): 600 Watts
Outlets: 2 NEMA 5-15R
Input Voltage: 12V DC nominal (10-15V DC)
Output Voltage: 120V AC / 60 Hz (nominal)
Output Waveform: Modified Sine Wave
DC Input Connection: Cigarette Lighter/ Accessory Plug
Max Efficiency: 90%
Thanks
Reply to texray00
Specs are nice, but if the PSU is indeed malfunctioning, it's probably not going to be operating to spec. You need to measure the voltage.
Reply to frozenlead
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Power Inverter
There are 1996 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bios passwort vergessen laptop acer Extensa 5220
By Brett928S2, 2 hours ago:
Hi :) We are NOT allowed to help with passwords here at Toms... All the best Brett...
Best offers
Top experts
