I have a ViewSonic VG2230wm and of late, when I power on, there is a slightly audible high pitch sound originating from it and it has problems powering on, with the power indicator going off shortly after pressing it. The sound starts once the video appears on the screen after much playing with the power switch to get it to turn on.
I previously used Google to try to identify problems like this, but have not found one that exactly fits the symptoms. Thus I do not know if the problem is originating from a faulty inverter transformer or from capacitors or another component. I've not pulled it apart as yet to determine what could be the problem but would like some ideas what could be the issue with it.
Suggestions would be appreciated.
Thank you,
DW
Thank you,
DW
