Tom's Hardware > Forum > CPU & Components > CPUs > Cleaning Thermal Compound from CPU's
Forum CPU & Components : CPUs - Cleaning Thermal Compound from CPU's
Just a quick question. What do people use to clean the thermal compound off an old CPU. I'm, putting a new CPU in one of my computers, and don't want to damage the old processor(AMD), by using something to harsh on the CPU.
I was planning to use plain old rubbig alcohol to clean it. Will this damage my old CPU?
Any help is appreciated.
Thanks.
Sponsored Links
Natural alcohol or 91% isopropyl alcohol would be best. Alcohol evaporates very quickly and cuts through thermal grease like nothing. Not sure about thermal(wax) pads though.
Your alcohol is probaly 70% isopropyl (30% water). It will work, but it won't be quite as clean. Doesn't evaporate as quickly either, but that's not a big issue. Just make sure there is no voltage running to your CPU when you clean it ;').
53 69 67 6E 61 74 75 72 65 20 69 6E 20 48 65 78 21
Reply to Bahumut
Acetone based nail-polish remover works very, very well. Just try to get something that is as additive free as possible. I think it cleans up a bit better than alcohol.
-Brett
Reply to smitbret
Thanks guys, I feel more comfortable now.
Reply to aspalmat
Your on the mark Pal!!
F-DISK-Format-Reinstal DO DA!! DO DA!!
Reply to addiarmadar
I use hot water and dishwashing detergent. The core is sealed, their's no place to get water inside. Just shake the water off after rinsing and allow to air dry.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
There are 993 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
