Home theater setup guide 21 x 12 room
Hello,
looking to set up a apnaSONIC AE 7000 IN A 21X12 ROOM WHAT IS THE LARGEST SCREEN SIZE WITH MAXIMUM QUALITI I SHOULD BE USING JUST A NOTE ROOM WILL BE COMPLETLY DARK
2 answers Last reply
More about home theater setup guide room
  1. According to Projector Central, the Panasonic PT-AE7000 maxes out at a 125" diagonal or a 16' 5" throw distance.
    Projector Central Panasonic PT-AE7000.
    I'm not sure why this is, but my Optoma HD20 doesn't seem to have this limitation. It may be that the lens simply won't focus beyond that point. I don't know.
    -Wolf sends
  2. Maximum quality on the Biggest screen…. You gotta compromise. If you are willing to sacrifice picture quality and go for the largest screen, you should get a projector. However, if you are one of people who thinks PQ is more important than anything else, you should check out mammoth size flagship models by the major TV manufacturers. Samsung just revealed 75" LCD TV and LG is gonna release 84" 4K LCD TV soon. Both of them have 3D and Smart features.
HDTV Home Theatre Screen Size
