Wifi connection from mobile phones to tv and pc
Last response: in Cell Phones & Smartphones
February 2, 2013 4:26:34 PM
how can i connect from my htc android cell to my tv or dell pc
a b Ë Android
February 2, 2013 5:09:16 PM
If you don't want to use the usb cable then you can use the blue tooth connection , but that requires your tv and/or computer to also have blue tooth.
The best way is to have your phone connect to your home network and that way with the Pc and tv also connected to the network they can all see each other.
m
l
a b Ë Android
a b x TV
February 2, 2013 9:09:39 PM
for data transfer..... usb cable is the easiest way.
m
l
