Spontatneous Reboots GX-270
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
We have several hundred Dell GX-270s in my office. Over the last few
days, several of them have started to spontaneously reboot. Anyone
else have the same problem, and if so how did you resolve it.
Dennis
G
Guest
Guest
"Dennis Gross" <grossde@sec.gov> wrote in message
news:d7afc9f6.0411010851.4e831f60@posting.google.com...
> Dennis
Have you verified that the (external) power source(s) for those boxes are
clean? If needed, swap some boxes around from (reboot) location to (good)
locations.
Aside from that, any error messages, any logs in the event viewer? What OS?
Has XP SP2 recently been installed or hotfixes?
Stew
rod
180
I have a similar problem and have pretty much decided it is heat. Make sure
you have plenty of ventilation as the GX260 and GX270 series run hot. I have
also lost about 7 hard drives and 3 power supplies in the last 8 months.
Rod
> Dennis
G
Guest
Guest
Remove the spyware.
Ted Zieglar
> Dennis
G
Guest
Guest
"Rod" <bigguy34NO@SPAMcox.com> wrote in message
news:dLAhd.197826$a85.143657@fed1read04...
>have also lost about 7 hard drives and 3 power supplies in the last 8
>months.
> Rod
Any of the now-infamous "thermal event" messages?
Stew
rod
180
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:NgChd.8596$T_.604@bignews4.bellsouth.net...
>>sure you have plenty of ventilation as the GX260 and GX270 series run hot.
>>I have also lost about 7 hard drives and 3 power supplies in the last 8
>>months.
>> Rod
> Stew
Yep, you got it. Been there done that.
Rod
G
Guest
Guest
"Ted Zieglar" <teddyz@notmail.com> wrote in message
news:4186ce89_1@nnrp1.news.uk.psi.net...
> Remove the spyware.
> Ted Zieglar
Spyware in a secure corporate network environment? Never! :)
Stew
G
Guest
Guest
I must be missing something, our file server is a GX270, and it runs
so cool it occasionally spins its fans all the way down to silent.
Never had a thermal problem (or any other) with this box.
G
Guest
Guest
<William P.N. Smith> wrote in message
news:v12fo0hnqtjg78mjs3gn89d1nj8sn8tufg@4ax.com...
I don't think the (largest) mid-tower GX270s have quite as many issues with
this as do the smaller form factor models. Those small ones run warm - very
warm, and their case ventilation is almost non-existent.
http://forums.us.dell.com/supportforums/search?board_id=oplex_other&submitted=true&q=thermal+event&x=0&y=0
The GX260s, 270s, and even some of the 280s seem to have this nasty habit
(some of them).
Stew
G
Guest
Guest
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message news:<_9Mhd.14128$T_.9640@bignews4.bellsouth.net>...
> (some of them).
> Stew
Interestingly, I moved the box from the carpted floor to atop my desk,
and voila, no problem. I had a stand underneath the tower, but the
static must have been causing problems.
