Satellite signal over ethernet
  • Satellite TV
  • TV
  • Ethernet Card
  • Converter
  • Cable
  • Home Theatre
Last response: in Home Theatre
August 8, 2012 11:55:25 AM
I have a tv setup in a bonus room in our detached garage. I already have a Cat-5 cable run underground to that building and would like to use that cable to carry the satellite signal from the house. I need a coaxial to ethernet converter and then an ethernet to coaxial converter to connect to the satellite provider's box, which then connects to the tv. Any ideas?
More about : satellite signal ethernet
a b x TV
August 8, 2012 9:38:31 PM
You are looking for a device called a video balun. These devices dont' work through a router, and are simply an extender for your existing video cable.
http://www.svideo.com/videobalun1.html
Pick your signal!
m
l
a b x TV
August 8, 2012 11:46:00 PM
Somehow i read that wrong.... But you can't actually do what you're trying. Your dish is powered by the receiver, you will have to use a standad RG6 cable. Perhaps an alternative would be to put a receiver somewhere close to your line where you can connect an rg6 to the dish, then use a balun from that point.
m
l
