How to connect Olevia LCD tv to basic cable?
I have a 6 yr old Olivia LCD tv, Model LT37HVS. I cannot locate the original remote, so I have purchased a universal remote. I have connected an RF Cable directly into the TV, in the DTV connection. I have also tried the ANT connection. In the DTV connection, with the source set to DTV, I get a message to Please scan channels. But I cannot figure out how to make it scan the channels. I am thinking it is not connected properly, but I don't know what else to try. How can I connect this TV directly to basic cable (no cable box)?
1 answer Last reply
More about connect olevia basic cable
  1. There's nothing wrong with your connection. You need to figure out how to get into the On-Screen Display (OSD) using your universal remote. Once in the OSD, you should be able to navigate to the channel set up section and scan for channels.
    Manual for the Olevia LT37HVS
    -Wolf sends
Digital TV TV Connection LCD Cable Home Theatre
