White spots on my mitsubishi projection tv model WD 65735
- HDTV
TV
- Western Digital
- Mitsubishi
- Home Theatre
Last response: in Home Theatre
OAR
August 11, 2012 9:51:19 PM
Sad mitsu ownwer
January 13, 2013 2:13:02 PM
Reply to Sad mitsu ownwer
m
l
- mitsubishi tv model # wd 60c9 white spot remover - Forum
- Mitsubishi projection tv wd-60638 white color has pink hue - Forum
snegrete8721
April 20, 2013 1:30:43 PM
Sad mitsu ownwer said:
I have a Mitsubishi WD65733 I have white dots that turn into black holes. They are about 1/8 of an inch in size.What is the cause and how do i get it fixed. Is this going to happen again in a couple of years ?
Is Mitsubishi doing something about this ?
How do I join the class action lawsuit?
Reply to snegrete8721
m
l
shanehamilton
May 14, 2013 4:59:49 PM
shanehamilton
May 14, 2013 5:01:56 PM
Best solution
FOXIFOX2001
September 12, 2014 3:43:00 PM
TXgal
September 17, 2014 1:42:58 PM
We started with a white dot here and there and now they practically cover the whole screen and it's difficult to see the picture.
I called Mitsubishi Consumer Relations at 800-332-2119. I gave them the model number and serial number. The best they could do for me was send their service people to my house to replace the part, which they said is "free" but we have to pay $200 +tax for "labor."
We have not made up our minds, as we are considering just buying another tv--definitely not a DLP model. The white dot problem seems prevalent in several different brands of DLP models.
Reply to TXgal
m
l
Scottia
September 29, 2014 9:01:28 AM
You need to re place a DLP chip it's $200.00 . I also found a diy on you tube . I have one if your interested. My husband wouldn't follow direction and decide to play with wires. There are a lot of diy on youtube but i think this is good.
<iframe width="560" height="315" src="//www.youtube.com/embed/C9fiv4bI1qI" frameborder="0" allowfullscreen></iframe>
Reply to Scottia
m
l
SteveDr
October 2, 2014 12:12:27 PM
Scottia said:
You need to re place a DLP chip it's $200.00 . I also found a diy on you tube . I have one if your interested. My husband wouldn't follow direction and decide to play with wires. There are a lot of diy on youtube but i think this is good.<iframe width="560" height="315" src="//www.youtube.com/embed/C9fiv4bI1qI" frameborder="0" allowfullscreen></iframe>
A place called shop jimmy sells the chips and has excellent videos for replacing them. Basically the tiny mirrors in the chip get stuck and it gets worse as time goes by. I replaced mine in a Samsung set for about $175 for the DLP device. It wasn't difficult, just removing some boards and connectors to get to the device, putting the new one in, and adjusting it's physical position so that it aligned correctly on the screen before tightening it down.
Reply to SteveDr
m
l
Read discussions in other Home Theatre categories
