Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Combine network connection speed
Forum Windows XP : Windows XP General Discussion - Combine network connection speed
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have 2 network connection:
1. Wired LAN
2. Wireless LAN
I have both enabled and running well in my laptop. Wired LAN connect to
the Internet through Server 1 which subscribe to ISP 1. Wireless LAN
connect to the Internet through Server 2 which subscribe to ISP 2.
I'm not sure on one thing, when I download a file, says 20 MB, is that
file downloaded through either one of the LAN connection? Or it will
utilize both the wired and wireless LAN to download the file?
If by default, it will only use either one of the LAN connection, is
there any way to configure it to use both of the LAN connection?
Peter CCH
Sponsored Links
In article <1125511680.905160.310340@f14g2000cwb.googlegroups.com>,
>1. Wired LAN
>2. Wireless LAN
>Peter CCH
It will use one connection or the other, but not both. To tell which
one, look at the default route entries (lines starting with 0.0.0.0)
in the route table. It will use the one that has the lower metric
value (the last number in the line). To see the route table, open a
command prompt window (Start | Run | cmd) and type:
route print
Windows doesn't have a way to use both. You might be able to find
third-part "connection teaming" software that can do it. I've also
heard of broadband routers with multiple Internet connections.
Best Wishes,
Steve Winograd, MS-MVP (Windows Networking)
Please post any reply as a follow-up message in the news group
for everyone to see. I'm sorry, but I don't answer questions
addressed directly to me in E-mail or news groups.
Microsoft Most Valuable Professional Program
http://mvp.support.microsoft.com
Reply to Anonymous
There are 1368 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
