G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hello--
Looks like I've got a couple of issues here. The first one, probably a
minor thing, is that only half my backbox lights light up. Like if you
divided it in half with a diagonal line, the upper right is all lit up
and the bottom left is dead. I thought it might be a fuse but they all
look good (although maybe I'm missing one, since I'm pretty much a
newcomer to pinball work).
2nd problem is that I've got 2 lines out on the dmd. And it's the
dreaded ribbon cable model (I've heard this is bad). Is there anything
that can be done?
Thanks
Aaron
Hello--
that can be done?
Thanks
Aaron
