Archived from groups: alt.sys.pc-clone.dell (
More info?)
Bob Pownall wrote:
> Regular readers of this thread may remember that I posted a week or
> two
> ago with some questions about upgrading my Inspiron 8500 from XP Home
> to XP Pro. (The upgrade was done at the recommendation of the IT
> support people at my university, in order to solve a problem I had in
> connecting
> to shared network drives. As it turned out, the upgrade didn't fix
> the problem. To their credit, the IT guys response was "Well, it
> should
> have worked! We'll send somebody out Monday to figure out what the
> problem is." Of course, if the problem with the network drives turns
> out to be unrelataed to XP Home vs. XP Pro, I'm out the cost of the
> upgrade...)
> Following the upgrade, I've got a couple of annoyances. They don't
> quite rise to the level of a problem, but they're definitely
> annoyances.
> *Every* time I boot my I8500, I get the message "Found new hardware:
> Alps Touch Pad" and "Found new hardware: Logitech-compatible Mouse
> PS/2".
> In addition, the "Found New Hardware Wizard" window appears, with the
> message:
> Cannot install this hardware
> There was a problem installing this hardware
> Logitech-compatible Mouse PS/2
> An error occurred during the installation of this device.
> The class installer has denied the request to install or upgrade this
> device
> Both the touch pad and the Logitech mouse appear to work correctly,
> but
> why (especially with the touchpad) are they always detected as new
> devices?
> In connection to the mouse, I should mention that I have two optical
> mice. A regular-size corded Logitech optical mouse that I use at home
> and a notebook (half-size) corded Kensington optical mouse that I use
> when away from home. The same error message occurs when either mouse
> is plugged in.
> I tried reinstalling the mouse drivers from the CD that came with the
> Logitech mouse but I got a message that newer drivers were already
> installed. Device Manager lists the driver for the Logitech mouse as
> Driver Provider: Logitech
> Driver Date: 6/21/2003
> Driver Version: 9.78.0.0
> (I don't have the info about the driver for the Kensington mouse - I
> forgot to write it down, but I'm pretty sure it's different. For one
> thing, I think the provider is KYE, not Logitech. I haven't checked
> the Kensington web site for newer drivers. The Kensington mouse
> didn't come with an installation CD.)
> I wanted to try reinstalling the touch pad drivers but I can't find
> the Dell resource CD right now. I still need to check the Dell web
> site for updated drivers. For some reason, Device Manager
> recogizes the touch
> pad as an Alps Electric Touch Pad, but lists the Driver Provider as
> Unknown, the Driver Date as Not Available and the Driver Version as
> Not Available.
> Any suggestions about what else I can try?
> Bob Pownall
