Tom's Hardware > Forum > Systems > Dell > Memory Problem: Dimension L933R
Forum Systems : Dell - Memory Problem: Dimension L933R
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi,
I am having trouble with upgrading a Dimension L933R memory. The
machine has 64 MB and running Windows XP Home. I got a 128 MB (PC133)
from BestBuy. When I put the new memory into the second memory bank
while having the original 64 MB untouched, the machine keeps rebooting,
but won't go into XP. The BIOS does see a total of 192 MB. If I put
the 128 MB in the first memory bank alone or along with the 64MB, the
machine hangs up at memory test and only sees 68 MB.
On the packing slip, I did see the original 64 MB is PC133. I went back
to BestBuy and got another 128 MB of the same type of memory. Still the
same problem. What have gone wrong with the memory upgrade? Does it
matter which memory bank has the smaller memory chip?
Thanks in advance for your help!
Terry
Sponsored Links
How many chips are on the new module? Most PC133 RAM these days is high
density (will have 4 chips on a 128 MByte module). This won't work with the
Dimension L series - it needs low-density RAM (i.e., you need an 8-chip 128
MByte or 16-chip 256 MByte modules).
"Terry" <gobeyondgobeyond@Rem0ve.Yahoo.com> wrote in message
news:MPG.1b0ff22ffa05bbf298968b@news.tc.umn.edu...
> Hi,
> Terry
Reply to Anonymous
Terry <gobeyondgobeyond@Rem0ve.Yahoo.com> wrote:
>Hi,
In addition to Edward Neth's good advice, keep
http://www.crucial.com in mind, whether you intend to buy your
memory from them or not. Their memory locator is quite good, and
will let you check out the specs for the memory suitable for your
given Dell model.
For the L933R, this is what resulted:
http://www.crucial.com/store/listp [...] &submit=Go
Converted to a TinyUrl in case that link wrapped and won't work
by clicking on it:
http://tinyurl.com/2nyap
OJ III
[Email sent to Yahoo address is burned before reading.
Lower and crunch the sig and you'll net me at comcast.]
Reply to Anonymous
In article <Ufspc.2832$M43.2577@newssvr16.news.prodigy.com>, ejn63
@netscape.com says...
Edward, Thanks so much for the help! Will check out the memory chips.
Terry
Reply to terry
There are 625 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
