Archived from groups: microsoft.public.windowsxp.general (
More info?)
Hi,
Then the next thing to do is check for an update to the motherboard drivers,
specifically the ide controllers. Do not rely on WinUpdate for this, they
should be gotten from the manufacturer.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Arsalan" <arsalan_aslam@hotmail.com> wrote in message
news:uFXn0p$rFHA.1032@TK2MSFTNGP12.phx.gbl...
> Tried chkntfs /d but still not solving the problem, and my PC doesnt have
> printer or scanner.
> "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
> news:uPEg6P6rFHA.3640@tk2msftngp13.phx.gbl...
>> Hi,
>> Click start/run, type cmd and click ok. From the prompt, run:
>> chkntfs /d
>> And hit <enter>, this will clear the dirty bit that causes chkdsk to run
>> at boot. If it happens again after doing this, you may have a timing
>> issue with one of the disk controllers or hard drive. There is also this,
>> which happens if certain scanners are/were attached to the system:
>> Chkdsk Runs Each Time That You Start Your Computer [Q316506]
http://support.microsoft.com/?kbid=316506
>> Best of Luck,
>> news:eqefD$5rFHA.1252@TK2MSFTNGP09.phx.gbl...
>>> For some reason, even if i shutdown my computer properly, the disks are
>>> scanned everytime on startup ? Can anyone tell me whats the problem is ?
>>> Its saying that windows wasnt shutdown properly, but it does.
