Yes No
Ads
Tom's Hardware > Forum > Home Audio > General Discussion > PC monitor speakers buzzing noise
Forum Home Audio : General Discussion PC monitor speakers buzzing noise
My computer monitor's speakers have started making a constant buzzing sound. When I switch the connection over to my TV, the TV starts to buzz, and the monitor stops. Disabling the sound on my computer doesn't do anything, but unplugging the light-green sound cord makes it stop. Anyone have any idea what is causing the buzz?
Message edited by Hatless on 10-26-2011 at 01:31:06 AM
Reply to Hatless
There is a ground loop between your cable TV (cable internet) and your system.
Install a cable TV isolation transformer, at the point of entry into your house.
You have 2 grounds, one from the cable company and one from your house wiring.
You need to isolate one of the grounds, and the buzz will stop.
------------------------------ My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
Reply to soundguruman
There are 1906 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
