Hello,
I'm having a bit of trouble with Win 7 pro 64 bit. Here are my options concerning power usage: I put it on high performance when I don't want the computer to go to sleep. I put it on power saver when I leave for awhile and I obviously want to save power with it asleep. I switch between these plans daily. What I have been noticing is that when it is going to sleep I'll come back like 2 hours later ( the plan is fall asleep in 30 mins). And I'll find that the computer is still on. The monitor is on sleep mode but everything else is still on. So naturally I'm like wtf? So when I move my mouse and try to wake it up it doesn't respond, the monitor is still sleeps and I end up having to restart my copmuter to get it running again.
The other problem is when it is shutting down. It usually takes with my SSD less than 30 secs to shut down, I timed it one day and it took 15 mins to shut down. There were no updates to install it just sat at the Shutting Down screen for 15 mins. (Now this doesn't happen all of the time). I'd say once a week. But the problem above almost every day.
It's getting really annoying so I appreciate any help that you can give me.
System Specs:
http://pcpartpicker.com/p/nNgF
System Specs:
