1_What is your budget?
500 euro
2_What is the size of the notebook that you are considering?
Either 17" or 11.x"
3_What screen resolution do you want?
For 11.x-13" - 1366x768 (HD), 16:9 aspect ratio
For 17" - 1600 x 900, 16:9 aspect ratio
4_Do you need a portable or desktop replacement laptop?
Either a 11.x" up to 13" portable
OR
17" desktop replacement
5_How much battery life do you need?
For desktop replacement the battery life does not matter at all
For the Portable it should be 4h+
6_Do you want to play games with your laptop? If so then please list the games that you want to with the settings that you want for these games. (Low,Medium or High)?
I will not be playing any games
7_What other tasks do you want to do with your laptop? (Photo / Video editing,watching movies, Etc.)
Some photoshop
Some Video editing
8_How much storage (H.D.D Capacity) do you need?
Min 160 GB
9_If you are considering specific sites to buy from, please post the links to them.
Considering the following products and most likely going to order from there too, unless I find another place that has what I need at a decent price that ships to Malta
http://www.bhphotovideo.com/c/product/672343-REG/Toshiba_PST1LU_002002_Satellite_T115D_S1125_Notebook_Computer.html
http://www.laptopsdirect.co.uk/ASUS_K70IO-TY002V_Laptop_K70IO-TY002V/version.asp?refsource=ldawin
10_How long do you want to keep your laptop?
2 years
11_What kind of Optical drive do you need? DVD ROM/Writer,Bluray ROM/Writer,Etc ?
DVD ROM is just fine
12_Please tell us about the brands that you prefer to buy from them and the brands that you don't like and explain the reasons.
Brands are not important
13_What country do you live in?
Malta
14_Please tell us any additional information if needed.
A bit splitted here, with a portable I don't have to buy an extra PC later on and can use it for the home and on the go whenever needed (though not often but nice to be prepared) and just connect an external monitor.
With a 17" I got a desktop replacement but nothing to take with me if going somewhere.
500 euro
Either 17" or 11.x"
OR
Some photoshop
Some Video editing
Min 160 GB
2 years
Malta
