Archived from groups: microsoft.public.windowsxp.general (More info?)
Recently, the past few days, I've suddenly gotten warning ID 1517 in
the Event Viewer:
-Windows saved user XXX registry while an application or service was
-still using the registry during log off. The memory used by the
-user's registry has not been freed. The registry will be unloaded
-when it is no longer in use.
I installed UPHclean to discover where the problem was, and it said:
-The following handles in user profile hive UPSTAIRS\Yahweh
-(S-1-5-21-3380930672-3385292856-934256048-1006) have been closed
-because they were preventing the profile from unloading successfully:
Ok. Thanks.
Shutdown is not substanially longer. One second or so. I read that
page from MS before posting here, which is how I knew of UPHClean.
It doesn't answer the question of why it suddenly started with LSASS
and how to stop, nor whether there are other hidden effects that may
be more problematic. It may be true that this particular effect needs
no "resolution", but there may be another effect that does require
attention that has a common cause with the 1517 warning.
Basically, I'm simply curious as to the WHY of things, not just the
hiding of them.
>The way I see it, you have two choices, run UPHclean and have two
>Information events or uninstall it and have Userenv/1517, Userenv/1524 or
>Userenv/1500 Errors and Warnings and shutdown taking longer while trying to
>unload the registry.
>This MSKB article has not been updated since June 6, 2004.
>Troubleshooting profile unload issues
>http://support.microsoft.com/default.aspx?scid=kb;en-us;837115
After installing and running UPHclean my machine shuts down about two
minutes quicker.
This is the 1201 that I get...
Event Type: Information
Event Source: UPHClean
Event Category: None
Event ID: 1201
The following handles in user profile hive MYPENTIUM450\Wesley P. Vogel
(S-1-5-21-1708537768-1580436667-1202660629-1003) have been closed because
lsass.exe (436)
HKCU (0x3f8)
I believe that the (436) after lsass.exe is the PID (Process identifier).
This number will change every boot. Right now lsass.exe is 440.
Apparently lsass.exe is what loads and unloads the registry hives. I do not
know for sure.
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:ftkjh19petv1prqfpmrngjd6otv4cfe2fq@4ax.com,
Zonk <mistybarnyard@hotmail.com> hunted and pecked:
> Ok. Thanks.
> hiding of them.
> Thanks for your help. >
> Ron Z.
> On Sat, 3 Sep 2005 10:14:06 -0600, "Wesley Vogel"
>> to unload the registry.
>> http://support.microsoft.com/defau [...] -us;837115
Oh my. Two MINUTES faster? Mine take all of 4 seconds WITHOUT
UPHClean.
Anyhow, thanks for your replies. Maybe it will go away as mysteriously
as it began--my curiosity just gets the better of me. I have the event
viewer log going back nearly 2 years, and never had one of these
warnings until 2 days ago.
How long has UPHClean been installed?
Wes
In news:987kh1l7bs9llkm22kv0vn1oopu2rosjv3@4ax.com,
> UPHClean.
> On Sat, 3 Sep 2005 15:58:43 -0600, "Wesley Vogel"
>> minutes quicker.
In newslhkh15g73t39all90kqk085b1oto5oekp@4ax.com,
> Since a few hours after getting that first warning 2 days or so ago.
> On Sat, 3 Sep 2005 18:55:43 -0600, "Wesley Vogel"
Those dates aren't significant to me. I'm not sure how to proceed
troubleshooting. I retreated to a Ghost backup of a few weeks ago,
and the warning was gone. I went to Windows Update, got some of the
recent 'critical' patches the backup lacked, and within a couple of
boots, the warning had returned.
So, it could be an update causing the issue, but, since it wasn't
occuring _immediately_ after the update, maybe not. In other words,
I've got very little.
