N nahid2120 Honorable Nov 15, 2012 1 0 10,510 Nov 15, 2012 #1 Hello, My Driver(D) all folder color is blue .please help me..........
M mbarnes86 Splendid Sep 16, 2010 3,839 7 26,965 Nov 16, 2012 #2 Hi what problem is the blue color causing ? What color do you want it to be ? has it changed recently ? regards Mike Upvote 0 Downvote
H henkbas Distinguished Sep 12, 2011 91 0 18,660 Nov 16, 2012 #3 right click on the drive in explorer and deselect the compress data option... Upvote 0 Downvote
S ss202sl Glorious May 23, 2012 8,431 35 44,190 Nov 16, 2012 #4 Blue folders usually means it's compressed. If you right-click the folder and go to the properties, you should be ably to un-check the compression box. Upvote 0 Downvote
H henkbas Distinguished Sep 12, 2011 91 0 18,660 Nov 16, 2012 #5 bit of a smartass reply, wasn't it mike? Upvote 0 Downvote
