Side effects of overheating CPU
I read that when a P4 CPU overheats it slows down itself and so produces less heat (AMD CPUs just burn). So I was wondering when does having a hot CPU starts effecting performance? Temp wise I mean...
I benchmarked my CPU in Prime95 when it was hot (50C) and when it was cool (38C) and there was somewhat of a decrease in timings, meaning it was faster. (It's hard to tell from that benchmark what impact it would have on everyday performance like gaming). So I assume there's a temp from which the CPU doesn't perform as good.
Second question: How does the CPU slow itself down? Is it by underclocking? If it is, shouldn't I be able to see it at the My Computer or the CPU diagnostic?
I'm a nuclear reactor cooling system programmer, if you see me running, it's probably already too late.
5 answers Last reply
More about side effects overheating
  1. I have Winbond that monitors system temps with my Mobo. When it hits 64C it will nock me off from gaming online. That's CPU temp.
  2. Xbitlabs did an article on this a while ago. read all about it here:
    <A HREF="http://www.xbitlabs.com/articles/cpu/display/p4-temp.html" target="_new">http://www.xbitlabs.com/articles/cpu/display/p4-temp.html</A>
    Bottom line, cpu starts throtteling when it reaches ~70°C. However, its hard to know if it is indeed throtteling, I don't think there is a way to find out really...
    BTW, AMD's don't burn anymore, they shut down (XP).
    = The views stated herein are my personal views, and not necessarily the views of my wife. =
  3. If you want to know what it does, there is a very good video from THG that will show you what happens when Intel adn AMD CPU overheat:
    http://www.tomshardware.com/site/videos/index.html
    Asus P4C800-E Deluxe
    P4 3.0GHz HT
    1Gb Corsair XMS PC3200LLPT
    ATI A-i-W Radeon 9800 Pro
    WD 200Gb SATA
    Lite-on IDE Combo Drive
    Win XP Pro SP1
  4. Overall note, the cooler they get, the faster they are. The hotter they are, the more f-ups they make. Thats the price to pay when using a transitional metal.
    F-DISK-Format-Reinstal DO DA!! DO DA!!
  5. The video showing the Athlon burning up isn't really relevant to todays' athlons and chipsets, it's old tech - AMD has had a thermal protection method since the palomino Athlon XP, and we're a good few cores down the line since then(t-bred A, t-bred B, Barton). Granted the solution required some circuits on the motherboard so was reliant also on the motherboard manufacturer, but the specs AMD gave them would work if followed properly.
    The A64s IIRC have on-die thermal protection, so no special stuff on the mobo is needed.
    <font color=red>The preceding text is assembled from information stored in an unreliable organic storage medium. As such it may be innacurate, incomplete, or completely wrong</font color=red> :wink:
CPUs Performance
